C7 Z06 Check Engine Light
Old Yesterday | 07:18 PM
6200LT4's Avatar
6200LT4
Default C7 Z06 Check Engine Light
Driving my '19 Z06 with 24K miles on Sunday when I did a light pull then the CEL came back on. The car was down on power but other than that it ran smoothly.
Checked the codes today and it has P0325 & P0330. The fact that this is both knock sensor codes, is it likely an issue with knock sensor wiring, bad tank of gas? The car has almost a full tank of gas, any octane booster I should test out through this tank?
Old Yesterday | 07:33 PM
2001PewterWS6's Avatar
2001PewterWS6
What grade of gas did you put in it? 91 or 93?
Old Yesterday | 08:06 PM
6200LT4's Avatar
6200LT4
Always put in 93, I drove the car 2 weekends ago and filled up before parking the car, the CEL came on taking the car out this past weekend with a full tank of gas from the previous weekend.
Old Yesterday | 09:28 PM
2001PewterWS6
I would just clear the CEL drive the car normal until the fuel gets low then refill at a different gas station and see if that fixes your issue. No sense dumping in a $25 can of octane booster
To C7 Z06 Check Engine Light
