Idle quality question - too much rumble ?
I always have the feeling that this 400 SBC idle is a bit too “rumbly” “shuddery” for this cam.
it’s a retrofit roller cam.
Roller rockers possibly 1.6.
Don’t know if you can see this. I thought it would be smoother. Maybe there’s a miss ?
What do y’all think ? This is 900 rpm
https://youtu.be/RPQtV2qXQ8o?feature=shared
https://youtu.be/qai3a45Cfw4?feature=shared
At higher rpm is seems to smooth out.
Vacuum is high but has a very rapid vibration of the needle but very low amplitude. Also smooths out with rpm.
Engine probably has 3000 miles on it. Oil pressure very good.
You should check/adjust the rockers, as the oscillation of that vacuum needle might suggest you have a valve hanging open slightly (valve preload to tight)
I do wonder if the valve springs are appropriate for this roller cam.
I’ll check the valve lash
Also discovered that water pump bearing is not doing great. Nasty grinding sound.
Those XR cams are known for having very fast ramps on the lobes that cause quite a bit of valvetrain noise (not your issue, but something to be aware of).
I have no idea what springs are on there.
The heads are these aluminum RPC. They came with the 400. I can only presume that the springs came with the head.
I replaced the rather peaky hydraulic flat tappet cam with a retrofit hydraulic roller cam.
As I say, the idle seems to be fine, even at 750 RPM. It is just not as smooth as I would have expected.
Will pull and inspect the plugs later today
Water pump needs to come off. It’s making a racket. Won’t be able to test until new water pump comes in.
Plug 2 is tv only one a little different from rest
And then…
And a crispy boot on 5.
That said, the rumbling was there before the crispiness.
I think next step might be to check seat spring pressure.
EDIT:
@OMF , thanks for the input. Again, being overseas is always more challenging... Access to tools and parts and... skill.
I submitted a Summit order for the tools required to efficiently remove the valve springs. Included in the order are a micrometer to measure seat height and tool to measure the seat pressure. At this point, I am curious about the seat pressure and have decided that I will replace these springs anyway, whatever the reading. The seat pressure tool will be necessary for the installation of the new springs anyway.
Looking at all the symptoms. From subtle idle issues, to flat spot at mid-range RPM (with what sounds like exhaust lead clatter), to pulling strong at higher RPM and then suddenly giving up... I think the springs do need to be ruled out.
Stay tuned.
I cannot find any assembled heads or any valve springs.
No significant specs for any assembled head components either.
Suggest you measure Both lobe lift and valve lift; from those two your can calculate Your approximate rocker arm ratio.
Suggest measure both Intake And Exhaust valve lengths.
Suggest you measure your valve springs Installed Height when closed-On Seat as well as when Fully-Open.
Suggest you inspect valve springs for Any coil bind; check when Fully-Open.
If No bind, measure total cumulative distance of gaps between coils when Fully-Open ?
No mention of rocker arms' brand, type etc. Suggest you pull a few off and closely inspect. Perhaps RAs are noisy ?
The rockers are 1.55:1. And don’t seem to interfere anywhere.
Agreed on everything you said about these springs.
These RAs are not recognizable to me either
But my understanding is that Roller Lifter Cams require much higher spring pressures than flat tappet cams would. So if ones is running flat tappet cams on a roller there could be issues with lifters ramping off the cam lobes and rapping back down.
- Personally I do not think the springs themselves have anything to do with the rough idle.
- Comps HR lifters do make noise and one could get bleeding down.
- If the springs are way too strong for the HR lifters, then yes they could get bleeding down. But that would just mean more noise, less power, not sure it would even affect the idle.Maybe?
- With mild .510" valve lift you should not have any retainer clearance issues.
- That mild cam should make great vacuum at idle, and be steady.
- Fluctuating vacuum at idle could easily be one valve adjusted to tight, and leaking. Find a good video online to carefully adjust your hydraulic lifter preload. 1/4 turn or 1/2 turn. It is surprisingly easy to mess this up. And doing so will definitely cause a rough idle. My best guess is this. If not, likely the springs.
- Valve springs must match the cam. I know you had a high rpm race cam in there when you bought it. It would have had stiff springs. If you left them in that could be the source of your lifter issues. Check comp cams site for spring recommendations for that specific cam
- Link for comps recommended springs. 284# open. 134# seat.
This pdf of their catalog has the full specs;
Beehives and dual springs. #26986 beehives on pg. 289 and #986 dual springs on pg. 295
That 106 deg LSA is going to give you a rougher idle than the same cam with a more standard 110-112 LSA, but I wouldn't expect it to be objectionable. I would be looking at idle mixture and timing. Idle timing I would expect to be around 25-27 degrees with the vacuum advance connected. Those plugs look like your mixture is lean, which would explain the rough idle.
I do agree though that 110 LSA will produce more of a lope compared to 112 LSA.....with 400 cubes and a small cam I don't think this is the issue, I'm sure he has one valve with to much preload and it's hanging open.
Cheers, Forrest
The reason I am looking at the valve springs is because the "problem" appeared when I converted to a roller-cam. The idle feels... off. I think it should be relatively smooth with this cam.
Also, I pretty much checked everything else.
I think it would be a good move to replace the unknown springs with appropriate ones.
So, this camshaft wants: 134# seat. and 284# open. Is that correct ? The cam card has "986-16" written on it. I presume those are the recommended springs... but they seem to be no longer available on Summit, my favorite source.
Typically, Retro-Roller LIFTERS are considerably heavier versus OE Roller LIFTERS; heavier needs more spring pressure in order to maintain control.
Back when CUP motors still had Flat Tappets, they could & did rev higher than today's Roller CUP motors; because they had less valvetrain mass to control. And, to further complicate things, their Intentional Lifter LOFTING resulted in very short lives of both lifters & lobes. Spring technology still has physical limitations.
FWIW: I suspect OP's rocker arms are (in some respects) much like his heads.
Cheers, Forrest
I agree with 400 CID and that cam, the idle should be pretty smooth. I looked at the videos and they didn't tell me much. The idle is too high and that is masking any problem, if it exists. At 900 rpm it seems to run fine.
A valve hanging open wouldn't be the first thing I thought of, but of course it's possible. A compression check will tell us that in a hurry.
As for the valve train noise, that's the roller cam. Mine does the same thing.
My advice to the OP would be to do the compression test to satisfy yourself that the valves are closing properly. Then check the timing at idle. Make sure you have about 25 degrees of advance. If all that checks out, it's the idle mixture.
The engine in managed by a Holley Sniper. Timing is computer controlled. Properly phased, TDC - whole nine yards.
RFI shielding and wiring is by the book.
Compression test is spot on.
Valve lash is spot on.
I triple-checked everything.
The only thing I have not yet checked are the springs. As they are unknowns, it makes sense to replace with quality and appropriate ones.
Also, yes - I do know that this cam has a noisy valve train operation. It is the shuddering that is tough to see on the video.
Let's put the right springs on there and see what happens
