I'm not sure which one GM will call "approved" or what difference that makes. Any C8 can go on track, and prepping it I would imagine being basically the same. Biggest thing is brake pads and fluid, especially if you're going to be driving hard. Last thing you want is to boil them 😳. Find the correct cold psi to start and then monitor between runs. Do NOT rely on the display, get a quality hand held gauge. Do at least 1/2 lap cool down before coming in, maybe more depending on size of the track. Let it idle for a few minutes when you come in and open the boot. Monitor the transmission temperature... constantly.
Most likely you will need at least Z52 since the base Grand Sport doesn't come with the 4S tires OR the Z06 brakes.
Nobody seems to know what the stock brakes are but I'd guess whatever comes on a base Stingray which are not track rated.
Z52 will most likely be the minimum to make it equivalent to a base Z06/Z51 Stingray for track readiness.
At the same time those things are such easy fixes. You don't need the 4S tires to go on track. Run what ya brung, especially since a C8 isn't going to have snow tires or something. Brakes...a simple pad swap and fluid flush with high temp will suffice.
If you're just looking to have some fun and see what the cars capablities are, no need to go crazy. A little common sense goes a long way.
Oh yeah... most important... HAVE FUN!
Per the owners manuals base Stingrays aren't approved for track use, only those equipped with the Z51 package. That could mean warranty denials for base Stingrays if GM determined that any problems were related to track use.
I suspect the base GS will be approved for track unless the brakes really can't hold up. The E-Ray is approved for track use with all-season tires.
C4 of Year Winner (performance mods) 2019
E-Ray is approved with PS4S tires (ZER performance package). It specifically states in the track prep guide to switch to PS4S.
From the Owner's Manual: All Z06 models, E-Ray models equipped with the ZER performance package, and Stingray models equipped with Z51 performance package can be used for track events and competitive driving.
From the Track Prep Guide: Pilot Sport 4S tires are required for track driving ability. The E-Ray all-season tires may be replaced with the Michelin Pilot Sport 4S tires (standard with ZER).
My assumption is any GS/GSX will be track-approved if you switch to PS4S tires. Honestly, you could even track it with the all-seasons, but obviously, GM/Michelin isn't going to cover any abnormal tire wear if you do.
Every Corvette since 1984 is track ready. You might want to change tires, brake pads, or upgrade certain things depending on skill, but every Corvette is track capable from the factory.
I do agree with this. No matter what the manual states, any Corvette is track capable, you just might need to change tires or pads. Plenty of reports and even videos of people tracking base, non-Z51 C8s with success. And honestly, while the manual states the Z51 and above can be used for track events and competitive driving, it does not explicitly state tracking a non-Z51 C8 will void the warranty.
Z51 and above are track approved and GM will provide warranty even if tracked. Base SR can be tracked but GM will not warranty problems due to tracking.
How are they going to prove that you were tracking the car vs driving like a complete lunatic on the street or mountain roads? Where are they going to draw the line for "tracking", or is autocross ok but not a parade lap? The whole idea is preposterous.
GM likely feels the extra cooling of a Z51 won't risk overheating when pushed hard on the track. Historically, the GS has gotten the extra cooling of the Z06 models, so there's little reason to expect that to change.
On-Star is tracking you whether you pay for it or not.
I get it. But my point is more that the whole "warranty" issue is a boogeyman. Realistically, they're not going to warranty consumables like brake pads and rotors, tires, shocks, etc. If the car reports a bunch of over temp events they're gonna deny your warranty regardless of where or how it was used.
Reality is, the number of people who routinely track these cars is near zero (I know there's gonna be a bunch of people who come.outnamd say they do, but it's a TINY minority that barely registers in statistics - the vast majority of owners and buyers never see a track). Those who do recognize exactly how far (or not far more specifically) a warranty will cover them on a track car.
This whole thing is a mountain out of an ant hill.
There have been threads on this forum of C8 Z51 owners that have had their engine grenade on track and GM covered it under warranty. It is not a "boogeyman".
Are there people who blow up their base motors on track and don't get warrantied? Honest question, I don't have g out here enough to know.
GM will usually warranty failures related to stuff they did wrong regardless of use case. This is not a situation where the Z51 has a different piling system or something like that which would change this. At most, it's a cooling thing, but you should be watching your oil pressure, oil temps, trans temps, and coolant temps when on track regardless and adjusting accordingly.
I bet the base GS is covered because it has the same cooling. The non Z51 doesn't have the extra cooling and I think that's the issue GM has with covering track days.
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Try telling that to the 2015 Z06 owners with A8 transmissions. The car is OK on track as long as it's less than 80 degrees and you don't want to do a full session. Haha
