Power door locks not working
I purchased my 1992 Corvette coupe 2 years ago. The power door locks do not work. I dug into the issue today and did a search here. I have power at the main accy fuse located at the passenger side fuse panel. Tested it with my cigarette lighter which worked. Located the power door lock fuse under the passenger side hush panel. I found that it was blown. Replaced it and hooked up the door lock switches on each side (the door panels are off). The door locks still do not work. My questions are: Do all of the door electronic connectors need to be connected for the door locks to work? If not, I will test for power at the plunger connectors. I can't get my fat hands inside the panel to disconnect the connecter. Is there a way to do this or do I have to drill out the rivets to get the plunger motor out?
Thanks for any suggestions as always,
Regards,
Kevin
At the driver switch the orange/black is hot at all times. Comes from the Fuse in the aux fuse box.
The gray wire is (+) to UNlock. (-) to LOCK.
The tan wire is (-) to UNlock and (+) to LOCK.
You need to apply power to one of the wires and ground to the other. The gray and tan wires go directly to the lock motors.
Another validation check: When the tan wire gets a (+) pulse, the SECURITY light should go Solid-On. The alarm is armed. When the gray wire gets a (+) pulse, the SECURITY light should go back to flashing (with a door open), the alarm is disarmed.
Thank you again for the diagnostic steps,
Regards,
Kevin
Thank you again IHBD for the straightforward testing procedure.
Regards,
Kevin
As is clearly visible, some of mine were not.
That's where power comes from and is dispersed for the window switches.
If you find any bad ones, I'll find the source I used for those oddball repair terminals inside if needed.
Regards,
Kevin
These are the terminals...
Here's where I got em. He keeps em in stock...
https://www.ebay.com/itm/15561149390...Bk9SR6jE1faKZg
If it turns out that you do have a problem with those, guaranteed you'll destroy a couple of em while crimping them, so consider that. I bought 10 and only have three left. lol...
Also, good idea to take a cell phone pic of the terminal/wire color layout once you pop the hinge open on that connector. They fall out easy and you'l be left guessing which ones go where.
They sell aftermarket pigtails, imported from China, but the wires are different colors. Another good reason to take a pic when you pop the connector open, if you were to go the pigtail route instead. They looked kind of cheap and flimsy to me, though, so opted to repair the original connections with new terminals instead.
A few wires were only hanging on by one or two corroded strands of wire.
