NPP valves.
Old May 3, 2026 | 06:07 PM
kodpkd's Avatar
kodpkd
Default NPP valves.
For my 2014 A6 Stingray. I have the NPP valves. I understand in touring mode they are closed, and in sport mode they are supposed to be open. BUT, sometimes even in sport mode I can hear the quieter sound. This only happens when I am very light on the throttle. As soon as I get on the throttle they open. Is this normal? I thought in sport mode they were open all the time. Also, even in touring mode, when I shut down the engine, they open. I can see them closed with the engine running in touring mode. So I know they open and close.
My AFM valves have been tuned out.
Old May 3, 2026 | 06:15 PM
Exia's Avatar
Exia
Normal, sport mode does not mean fully open all the time. Sport mode means it opens under specific conditions (like throttle) and stays open for a certain amount of time, like 10 seconds after you get off throttle and closes.
Track is the same, except it keeps them open for longer before closing.
Tour is closed until you give enough throttle to open them, but they will close after you get off throttle.
The NPP valves are never fully open all the time in any mode. The mode just determines how they open and how long they stay open before closing.
Old May 3, 2026 | 06:36 PM
kodpkd's Avatar
kodpkd
OK, whew, now I am going to try the touring mode when I floor it. Thank you.
Took it for a drive. In track mode I could hear the, valves close sound, if I was in high gears and lug it a bit. As usual I couldn't find the reference in the manual.
Old May 3, 2026 | 08:09 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
If you want it loud all the time pull the NPP fuse. Then it will be open 100% of the time no matter what mode it is in.
Old May 3, 2026 | 08:26 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Get a mild to wild switch and you can open and close them when ever you want. I linked mine to my sunvisor buttons.
Old May 3, 2026 | 08:31 PM
kodpkd's Avatar
kodpkd
I am fine with how it works. I was just wondering why it was doing, what it was doing.
Old May 3, 2026 | 09:16 PM
mdolandese's Avatar
mdolandese
I thought if you kept it in track mode they were open all the time?
Old May 3, 2026 | 09:21 PM
DrivesWithTwoFeet
No they close at a certain RPM range. Don't remember exactly but like 1500 - 2000 rpm.
Old May 4, 2026 | 09:15 AM
kodpkd's Avatar
kodpkd
In track mode, it's hard to get them to close. You have to lug the engine a bit, not sure if it depends on what gear you are in.
Old May 4, 2026 | 09:34 AM
Zjoe6's Avatar
Zjoe6
In track mode mine will close below about 1600 RPM if I'm cruising along. I've always liked the way they set it up. My ears have taken a beating over the years.
Old May 4, 2026 | 09:43 AM
NORTY's Avatar
NORTY
In "tour" mode, they'll open @3500RPM.
In "sport" mode, they'll open @3000RPM.
Old May 4, 2026 | 09:45 AM
NORTY's Avatar
NORTY
Remove the fuse, and they'll be open all the time.
Old May 4, 2026 | 10:25 AM
cgladish's Avatar
cgladish
Have you checked the engine management settings in the option screen? This is what allows you to control the operation of the NPP option.
Pulling the fuse is not necessary, unless you have a C6.
Old May 4, 2026 | 10:55 AM
westsdad's Avatar
westsdad
Here's a discussion on NPP tuning using HPTuners.
https://www.corvetteforum.com/forums...questions.html
There are tables of what is set in the ECM for each mode. You'll need to read through the posts to get a better understanding, and it won't be for everyone.
Old May 4, 2026 | 12:51 PM
owc6's Avatar
owc6
The'14s only have an on/off option for engine sound management, unlike later years.
Eta when on, it is slaved to drive mode, when off it is open-ish. The range of loudness is not as wide as later years. It never gets as quiet as stealth or as loud as track on the later years.
Old May 5, 2026 | 03:40 PM
Bill Dearborn's Avatar
Bill Dearborn
It may depend on the year, but it definitely depends on the transmission. Based on owner comments over the years, I believe the 2014 settings may be different from those in the following years.
My 2015 Z06/M7 has the following Engine Sound Management settings: Auto, Stealth, Tour, or Track. When I select Track, the valves are open except when the car is in 5th gear at engine speeds below 1500 rpm. One reason the valves will close is to reduce objectionable exhaust noise when the engine is operating in Eco Mode (4-cylinder mode). Cars having the A8 transmission run in Eco Mode all the time (don't know about the A6) except when the transmission is in Manual Mode, whereas cars with the M7 transmission, the driver has to select ECO mode with the driving mode selector on the console.
Bill
Old May 5, 2026 | 04:07 PM
rtv900's Avatar
rtv900
for a manual trans
in track mode 5th gear they close below 1400 rpm's
otherwise they stay open
To NPP valves.
Old May 5, 2026 | 10:26 PM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
I have a 2019 GSM7.
In the 'Engine Management' settings, I have it selected to 'Track'.
Will I gain anything (ex. more exhaust sound) by pulling the fuse?
If yes, which fuse gets pulled on a 2019?
Thanks
Old May 5, 2026 | 10:55 PM
F4Gary's Avatar
F4Gary
It's fuse #42 on my '17 GS.
Old May 6, 2026 | 06:35 AM
Two Red Vettes
Would pulling this fuse make the exhaust any louder than just having the 'Engine Management' setting at 'Track'?
Thanks
