C5 won’t start after taking off dash.
Old May 3, 2026 | 08:51 PM
Marco88's Avatar
Marco88
Cruising
Default C5 won’t start after taking off dash.
I recently took my dash off to replace both a/c actuators. Everything is back on except for the dash, I took off the hazard switch off the dash and plugged it in the car. The car won’t start, the ignition turns on but it won’t crank. Does anybody know why?
Old May 3, 2026 | 11:35 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Can't tell you exactly why it won't start but if you know how to read your starting system wiring diagram you can start here.
Old May 4, 2026 | 10:00 AM
Moved to C5 Tech for more discussion.
Old May 4, 2026 | 10:18 AM
lucky131969's Avatar
lucky131969
Did you disconnect the lock cylinder connector when you took everything apart?
Old May 5, 2026 | 05:52 PM
mmartinez's Avatar
mmartinez
To the OP, did you or did you not plug the small two wire connector from the lock cylinder onto its mating connector?
Old Today | 04:29 AM
Marco88's Avatar
Marco88
Cruising
I got it to start, called a mobile mechanic. He turned the key and it fired up right away 😂. Drove it for a while, it did it again, this time I slowly turned the key it sounded like it wanted to fire up, I keep turning it slowly until it fired up. I’m thinking it has to do with the starter going bad. Thank you guys so much for the responses, you guys rock!
To C5 won’t start after taking off dash.
