Sponsored by: Wheel Design
Protective coating - what do you use?
Old May 6, 2026 | 01:58 PM
gregbC8's Avatar
gregbC8
Navigator
Default Protective coating - what do you use?
Overwhelming how many products you have to choose from now to protect your paint, I don't know where to begin? When I received my C7 years ago, I used Dawn to remove previous coatings and then I used Blackfire Total Polish & Seal for the base and then Prima Hydro after each wash. Now I see something called ceramic coating.?
Expecting my C8 any day now. What would be your process and products? Thanks so much in advance!!
Popular Reply
May 7, 2026, 02:00 AM
C5racecar's Avatar
C5racecar
Cheap, quick, easy.
Old May 6, 2026 | 02:50 PM
spacecowby573's Avatar
spacecowby573
I had mine ceramic coated with crystal serum. Super easy to wash and take care of. I was just texting the guy who did it the other day that it takes me longer to set everything up to wash the car than it does to actually wash it. Well worth the money in my opinion.
Old May 6, 2026 | 03:08 PM
SpeedyATL's Avatar
SpeedyATL
Xpel ppf and Xpel ceramic coating - professionally installed. Hard to beat it for protection and gloss/shine.
Old May 6, 2026 | 03:12 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I use Liquid Armor ceramic. Comes in a paste form. H9 hardness. Easy to apply. The detail spray works well with it for a quick shine.
Old May 6, 2026 | 05:07 PM
5632's Avatar
5632
ADAMS Ceramic.
Old May 6, 2026 | 05:32 PM
85Z514+3's Avatar
85Z514+3
My 2026 Stingray is currently at my PPF installer getting wrapped with Xpel and Xpel ceramic coating. This is the best protection I have found over the last 10+ years.
Old May 6, 2026 | 06:16 PM
ZORANGE's Avatar
ZORANGE
Originally Posted by 5632
ADAMS Ceramic.
This is the way...on top of STEK PPF (thicker than Xpel).
Old May 6, 2026 | 06:41 PM
Zormecteon's Avatar
Zormecteon
Adams GRAPHENE Ceramic. The "nine year" stuff, not the spray on, is what's in the C8.
If you're thinking of doing it yourself, keep in mind that best results come if you do all the steps of paint correction first. It's less time consuming with a NEW car, but should still be done for best results.
I have the "one year" Adams Graphene Spray On on my other vehicles, all professionally applied, with proper paint correction. I use Adams Graphene BOOST as a drying agent when I wash the car(s) and even the one year is holding up well after more than a year. All cars are parked outside (the C8 under a car port) all year long. I'm still getting little 3/8" or less beading when it rains on them.
I still need to clay the car(s) especially when the pollen starts in the spring. (Using graphene detail spray as a lubricant for the clay)
Old May 6, 2026 | 07:23 PM
Andybump's Avatar
Andybump
I use Griots products. I use the surface prep pad, by hand, on the paint, lubricated with Griots Speed Shine. It functions as a synthetic clay bar. It is not abrasive. But it does leave the surface very very clean and smooth. And, I use Griots Best of Show liquid wax. For detailing, I use Griots best of show detailer. It can be used in direct sunlight if necessary.
I also use the surface prep pad on glass. Again, its not a polish, not abrasive. But its good at removing impurities.
Old May 6, 2026 | 07:25 PM
Action Andy's Avatar
Action Andy
1) Paint correction a must. Then PPF followed by Ceramic coat. I use Adams mega foam and also use Gyeon detail spray....
Can't beat the shine on a black car.. But most important find what works for you and have fun!!!!
Old May 6, 2026 | 07:48 PM
KMiles 1's Avatar
KMiles 1
Modesta ceramic coating.
Old May 6, 2026 | 08:07 PM
Donwuan's Avatar
Donwuan
I use one of these after and between washes. I do my own clay bar and polish every couple years.
Old May 6, 2026 | 08:38 PM
Avanti's Avatar
Avanti
There are about as many preferences as there are options... and the number keeps growing. Do an "Advanced search" across any C-series Forum section here and find a gazillion threads about coating.
Old May 6, 2026 | 10:59 PM
KevDude's Avatar
KevDude
I use Adams 9 year advanced Graphene Ceramic. All of my products are Adams, including car wash foam cannon, detail spray, graphene spray, double soft towels, etc.
Old May 6, 2026 | 11:56 PM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Paint correction, then Ceramic Pro applied by a licensed shop.
Old May 7, 2026 | 12:37 AM
SimCar's Avatar
SimCar
NCM Lifetime Member
NCCC Lifetime Member
Icon Rocklear. 2 coats. Right now the C8 has 1 coat complete and 2nd coat in 2 weeks. I have used this on 6 other cars two of which were Corvettes. I've been happy with the results. It must be applied by a licensed shop.
Old May 7, 2026 | 01:12 AM
Zormecteon's Avatar
Zormecteon
As far as product lines go, I use both Adams and Griots. They both have some products that are "better" ( I like more ) than the other. But this thread is about Paint Protection, so I won't go too tangential.
Soap, Adams Mega Foam, OR Griots, Foaming Surface Wash. Mega Foam can be used in direct sunlight (and smells better).
Detailer, Griots Best In Show Detailer or Adams Graphene Detailer. tho the Griots as mentioned earlier can be used in direct sunlight.
Clay, Griots or Adams. or Griots Clay Bar Pad, or Nano Skin. Adams clay comes in grades.
My 2¢
To Protective coating - what do you use?
Old May 7, 2026 | 02:00 AM
C5racecar's Avatar
C5racecar
Cheap, quick, easy.
Old May 7, 2026 | 06:22 AM
Ystayhm's Avatar
Ystayhm
Have ceramic coated 3 vettes myself using Gyeon.
my C8 has Expel on the touch screen to stop etching from hand oils
was aldo ceramic coated by CeramicPro in Sycamore Il and I use BeadMaker
Old May 7, 2026 | 06:39 AM
449er's Avatar
449er
CF Community Team
Professionally applied ceramic coating & ppf on the vulnerable areas is your best protection, Adams & Griots Garage make many quality car care products for do it yourselfers
