[C2] AC heater box removal hell
Old May 9, 2026 | 04:06 PM
c2vettehead's Avatar
c2vettehead
Default AC heater box removal hell
I think I got all the nuts but not sure. sucker won't budge.
anyone got good pics of how this thing is mounted (I. e. already removed from the car).
Old May 9, 2026 | 04:08 PM
c2vettehead
I'm assuming one doesn't have to remove the evaporater box (yikes!).
Old May 9, 2026 | 04:15 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Do you have the nut behind the radio
Old May 9, 2026 | 04:37 PM
Powershift's Avatar
Powershift
A factory AIM (Assembly Information Manual) shows all the attachment points. Most folks don't find the one or two hidden bolts or nuts at first. NWM gave you a good hint at one off them.
Larry
Old May 9, 2026 | 04:38 PM
c2vettehead
pretty sure that's the stud in the first picture near the red positive cable
Old May 9, 2026 | 04:54 PM
Nowhere Man
Nope. It's inside the car
Old May 9, 2026 | 05:14 PM
c2vettehead
the one labeled "prod nut"?
Old May 9, 2026 | 05:21 PM
c2vettehead
that nut on that silver bracket shown here?
Old May 9, 2026 | 05:25 PM
Nowhere Man
Yes
Old May 9, 2026 | 05:37 PM
c2vettehead
this guy on FB said:
"OK, I got the heater box out yesterday. What a struggle process if anybody’s interested remove water from radiator remove all heater hoses blow out the heater core remove all nuts from the engine side five in total remove glove box remove side panels from the council remove right hand, kick panel unhook all the cables and electrical from box. Remove radio remove air duct under the glove box. and off of the heater box 2 screws gently wiggle it loose tip the right side down and pull it out. It’s a tight fit. "
5 screws on the engine side? I only see four.
two screws? not sure what he's referring to.
also some mention you have to remove the blower motor.
true?
Old May 9, 2026 | 05:47 PM
c2vettehead
and this guy is talking about lower nuts accessed via below access panels? not in the AIM that I can see:
"problem is space to maneuver the big, long box, but also to remove the nut attached to the long stud coming through the firewall from the engine compartment (next to the wiper motor). I was able with great difficulty to remove the nut from the glovebox side, without removing the speaker, grill, a/c vents etc. I'm not sure whether the manual method or mine is easier or quicker. With the exception of one nut in the passenger right foot area, all the other retaining nuts are on the engine side of the firewall in front of the passenger's feet. MAJOR HINT: Take off the two "skid plates" underneath the frame on the passenger side. It allows easy access to all the lower nuts!"
Old Yesterday | 02:57 PM
c2vettehead
I'm not seeing any more studs or ways it's affixed on the bottom from this picture:
Old Yesterday | 03:04 PM
c2vettehead
I count at most 3, maybe four (two maybe on top, one side, one bottom) on the engine side , and 2 on the interior side (far right near vent, other aforementioned behind radio).
Old Yesterday | 03:05 PM
Nowhere Man
if you have all the nuts removed it could simply just be stuck to the firewall you going to need to gently rock it up and down to break it loose
Old Yesterday | 03:35 PM
c2vettehead
Probably the best picture(s) on the internet I can find of the engine side:
Old Yesterday | 03:40 PM
c2vettehead
I think THIS is it!?!?!?
Old Yesterday | 04:05 PM
Nowhere Man
that is the pivot for the deforester duct flap
To AC heater box removal hell
