C7 Key FOBs both died...how to re-program
Old May 11, 2026 | 01:47 PM
dvz's Avatar
dvz
Cruising
Default C7 Key FOBs both died...how to re-program
Has anyone had their Key FOBs just quit working? Both of mine somehow lost contact with the car...I can insert into steering wheel slot and drive, but cannot lock the car. And everytime I start the car, it says theft attempted.
How can I re-link Key FOBs to my car? I put new batteries in both the day this happened, but they will not communicate with the car.
Old May 11, 2026 | 03:55 PM
RonC7's Avatar
RonC7
The fobs ARE PAIRED to the car, otherwise they would not work in the steering column slot. No need to repair (reprogram).
- make sure fob batteries are good - near 3.3 volts and installed properly
- make sure car battery is charged
If neither fob will lock or unlock the doors you may have a remote keyless access problem in the car itself - check fuses. Start with the 2 fuses in the rear fuse block labelled Passive Entry or Keyless Entry.
Most parts stores can verify that the fobs are transmitting or you can buy a fob tester for $20 or so to verify.
I really doubt the fobs are your problem - more likely something in the car.
GL
Ron
Old May 11, 2026 | 03:57 PM
633BR's Avatar
633BR
https://www.corvetteforum.com/forums...s-and-rke.html
Old Jun 2, 2026 | 03:56 PM
dvz's Avatar
dvz
Cruising
Thank you very much. Interesting that they both quit at the same time...so you are likely on to something...that it's a problem in the car. I will check it out.
Darrel
Old Today | 01:45 PM
RonC7's Avatar
RonC7
I assume that the fobs were working before you changed the batteries.
Yeah, both fobs "died" at the same time. What is common to both fobs? 1) you changed both batteries (potentially weak / dead "new" batteries or BOTH installed incorrectly, 2) the remote keyless entry system.
First check the battery voltage and installation.
Don't go looking for trouble or causing yourself unnecessary work.
(I typically check new battery voltage and then change one fob battery at a time and verify operation)
I wasn't this careful in the old days when I had an ignition key. Now that it's a pain to get into the car without a fob and a pain to start the car I pay more attention...
Ron
To C7 Key FOBs both died...how to re-program
