Grand Sport vs Z06 from rolling start?
From a low roll or off the stoplight, not wound up in launch mode, just normal driving, on a short burst, low rpms, the GS should walk from the Z06 easily. Same weight, same gearing, massive increase in torque, massive increase in HP at low rpms.
Roll racing? Z06 has the win easily. If I had to guess official numbers for the GS I’d say 125 mph traps official (Z06 gearing definitely will help). Z06 has hit 135 in good air on the fast list, and is listed at 131 on Chevy’s website.
In the end it’s power to weight (a=Fm), you can’t beat Newton. Z06 has 135 hp over the GS on the top end. The GS has the power advantage at the low end so if you’re in that range you’re taking a Z06 down. On a road course the Z06 is in its element and will easily put the GS down.
On the drag strip the Z06 still wins because you’re sitting in the Z06’s power band for the entire run. Now when you start factoring in higher gears, rolling starts, shorter runs, the GS will be pound for pound be a challenge for the Z06.
