71 C3 code 44
Old May 11, 2026 | 09:13 PM
Jason71C3's Avatar
Jason71C3
2nd Gear
Default 71 C3 code 44
Hello all. My first Corvette, I’ve always been more of a Camaro, Chevelle guy.
Passenger side trans tunnel.
 Rear panel behind drivers seat.
So far I love it but like everything else I felt compelled to disassemble it and go through it completely. I removed the carpeting and found these assembly markings and was hoping someone can help me identify them. Car is a nom CE ls5 with M22 that appears to be original with partial vin,
Old May 11, 2026 | 10:11 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
The 44 is the internal plant job number that was assigned to your car before the VIN was assigned. This number ran from 1 to 500 then started over… As mentioned, it bears no direct correlation to your VIN. The bulkhead behind the seats shows 44 again as the job number AC meant that the car was to have air conditioning installed and PW meant the installation of power windows. If your car is a four speed, it will most likely have an M-20 transmission considering you car has (had) air conditioning. In 1971, the M-22 was only available with the LS-6 as well as the ZR-1 and ZR-2 packages.
Regards,
Stan Falenski
Old Yesterday | 08:30 AM
Jason71C3's Avatar
Jason71C3
2nd Gear
Thank you. Whatever transmission it turns out to be I'm not sweating it since the car is non original motor and rear and there is nothing notable about the car other than its a really cool big block 4spd car thats fun to drive. And for what i paid for it, i think it was a steal.
Thanks again,
Jason
Old Yesterday | 08:54 AM
Alan 71's Avatar
Alan 71
Hello Jason.
Welcome!!
There's something else interesting to be seen in the 2nd photo you attached..
The bit of black carpet that one can see the back side of does't appear to have the thin 'plastic' coating on it.
This is typical for the piece on the seat back bulkhead.
The majority of the carpet used through-out the interior typically has the coating.
This is a nice thing to see in an original car.
I look forward to seeing you on the Forum.
Regards.....
Old Yesterday | 10:29 AM
AKjeff's Avatar
AKjeff
Congrats on your Corvette, can we see more pictures?
Old Yesterday | 01:59 PM
Rowdy Rat's Avatar
Rowdy Rat
Jason,
You’re welcome and it sounds like you found a really neat car!
Like Alan and Jeff, I’d love to see some photos!
Regards,
Stan Falenski
To 71 C3 code 44
