So I drove over to the shop to get an alignment yesterday and when I turned the key off the engine didn't stop running. I tried a few times then just pulled the batt/tach plug off the distributor to shut it down. It does start so that kinda points to the switch maybe.
So I assume it might be the ignition switch on top of the steering column is broken or loose or the rack and pinion for the key cylinder.
I'm digging through Jim Shea's papers to find the steering column papers. I've managed to get all three papers using the way back machine.
Edit: I'm not finding anything in Jim Shea's papers about the ignition switch...
I have a 69, but the ignition switch is located in the same place. I think they even used the same switches for many years. If you lower the steering column, you should be able to get to the switch. It is a PITA because there might be several other things that have to be removed also, i.e. AC tubes. The switch comes with an alignment pin installed and you connect the rod from the mechanical switch and mount the new switch and fasten it in place. Once it fits in place then you remove the pin and pit it in a safe place in case you ever need it again. The Tilt column uses a different switch than the fixed column. Surprisingly, the switches are still fairly cheap. Test it before reinstalling everything to make sure all the alignment functions work correctly. You don't want to pull it apart again if you don't have to.
Well I can verify that the rack and pinion is working, now to get the steering column out of the car. I do see some Bubba wiring that I need to look at when I get it out.
JT
Does your '82 have rack & pinion steering ?
IIRC, those came with recirculating ball (Saginaw steering box) like all previous C3 ?
Did this car's PO retrofit it with rack & pinion steering ?
The rack & pinion I was referring to is the key rack & pinion the moves the rod that slides the ignition switch from position to position. On the drawing above it's called the ignition switch actuator assembly.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I am going off something I remembered from from 20 yrs ago and that you need to install a diode in the alternator wire (very easy fix) so the current from the alternator flows only one way (out) and dose not feed back into the alternator from ignition components keeping the engine from turning off.
It's been working fine for the last year and a half and just quit yesterday. I put a meter on the switch and B3 and G2 has continuity to B1 (battery) all the time no matter what position the switch is in so I suspect the switch is bad after 44 years.
Hmm, it's out. I put a jack stand under the steering column to support it while unplugging the plugs. I had to rotate it 90° CW to clear the brake pedal.
It was actually not that hard to get the steering column out of the car. I did have to rotate and twist a bit to get the lower flange past the brake pedal.
Might as well clean it up and paint it while it's out. I see Bubba has been hard at work on the turn signals so I'll replace that and the dimmer switch while it's out and easy to work on. I also think I'll change the lower bearing as it has some play. The rest feels good.
So much for going for a ride this weekend in the C3.
