87 Spark Plug Thread size
Old Today | 12:29 AM
c4sailor's Avatar
c4sailor
Default 87 Spark Plug Thread size
Anyone know the thread specification for the spark plug hole in the L98 head? I have my right front plug that feels like it's binding up part way when screwed in. Thinking about running a tap in there to "chase" the threads to clean them up. So, need the size of tap to use. Any other thoughts welcome.
Old Today | 05:45 AM
mazdaverx7's Avatar
mazdaverx7
The thread size and pitch should be 14x1.25. If you are re-threading a spark plug hole, I would recommend using a spark plug tap. They do not use a conventional tap handle, but rather use a 3/8 drive so that you can use an extention if needed and a ratchet to run the tap into the spark plug hole. I can post a picture of a few that I have if you'd like.
Old Today | 12:52 PM
standswithabeer's Avatar
standswithabeer
some time ago I watched a bike mechanic rethread a nearly inaccessbile spark plug hole on one of my bikes, he used grease on the tap threads to minimize chips dropping into the cylinder. not a bad idea imo.
To 87 Spark Plug Thread size
