Did full tune up, now has a stumble
Old May 16, 2026 | 08:08 PM
ButchN's Avatar
ButchN
Default Did full tune up, now has a stumble
Hi all.
I bought an 88 last week with 43K miles.
As I've always done when I get an older car, I go through it, which includes tune up.
So I bought all GM AC Delco parts from Top Flight, change cap, rotor, wires, plugs & used CRC on the MAF.
Wires are correct yet now it seems to want to slightly stumble or miss, can't tell, while driving.
I looked for broken vacuum lines, none, tapped the MAF while idling, it didn't stumble & there is no CE light.
Thoughts?
Old May 17, 2026 | 04:36 AM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
Did one of the new plugs get dropped on the floor or cracked when tightening during the install? You can also look at the inside of the cap for a crack....Run the engine in the dark and look for arcing👍
Old May 17, 2026 | 07:25 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Did you transfer ground strap from old distributor cap ?
Old May 17, 2026 | 07:51 AM
pltmgr's Avatar
pltmgr
Id check to see if the spark wires are fully seated on the plugs and in the cap.
Old May 17, 2026 | 02:36 PM
IHBD's Avatar
IHBD
Pro Mechanic
And I will add: That the firing order is correct.
Old May 17, 2026 | 03:31 PM
standswithabeer's Avatar
standswithabeer
just for clarity:
did it run well before you gave it a tune up? what CRC product did you use? what is a CE light?
Old Yesterday | 01:40 AM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
I've been guilty more than once myself of not reinstalling plug wires so that the boots are all the way seated. Have also crossed wires in the past.
So, yeah, post #s 4 and 5 are worth double, even triple checking. Sometimes the boots feel like they're snapped in but really aren't.
As an aside, I always put a timing light on it whenever I finish swapping out plugs and wires or anything ignition related as well.
Old Yesterday | 10:44 AM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
An extra bit, look INSIDE the spark plug boots when doing so, make sure the connector is there and good.
I had a less than one year old set and the connector in a boot was pushed back, sidewise. Only kind of worked because it was pushing against the spark plug tip. I only checked because it sounded funny putting back on, now do every time.
To Did full tune up, now has a stumble
