Torque wrench
Old May 17, 2026 | 09:06 AM
kodpkd's Avatar
kodpkd
Default Torque wrench
If you use a torque wrench, have it checked for accuracy. Both of mine were way off.
I purchased a torque calibration tool.
I can calibrate your wrench if you are local. I am in Loveland CO.
I have a really good HazeMaker IPA in the fridge.
Old May 17, 2026 | 10:42 AM
Tranz Zam's Avatar
Tranz Zam
It seems like a lot of wrenches get sloppy with smaller torque numbers, especially larger wrenches that go high into the hundreds.
Always a good idea to have wrenches recalibrated from time to time!
Old May 17, 2026 | 11:35 AM
EVRGRN's Avatar
EVRGRN
Good PSA and nice of you too offer a recal to local CF members.
Old May 17, 2026 | 12:17 PM
dcova's Avatar
dcova
Before stowing your torque wrench after use, it is a good practice to always unwind it.
Old May 17, 2026 | 12:59 PM
kodpkd's Avatar
kodpkd
Yes.
Old May 17, 2026 | 01:48 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
That's the common understanding with mechanics, and I do it.
But the common understanding is that pistol mags where the spring is under compression, can be stored for decades without any degradation. Lots of real world examples to verify. What would be different about the spring in a torque wrench?
Old May 17, 2026 | 03:36 PM
dcova's Avatar
dcova
The following is a copy-paste from the "Snap-on Torque Wrench 101" documentation:
Old May 17, 2026 | 03:50 PM
Gearhead Jim
St. Jude Donor '13
I agree that's the "official" way to do it, and that's the way I treat my two wrenches.
But there is a long history of of gun magazines being fully loaded for years or decades without problems, and spring engineers tell us that it's cycling (repeated loading and unloading) of springs that degrades them, not constant compression.
I'm trying to understand the difference.
Old May 17, 2026 | 08:40 PM
kodpkd's Avatar
kodpkd
No matter which wrench you purchase, it needs to be calibrated over time.
Old May 18, 2026 | 09:28 AM
kodpkd's Avatar
kodpkd
This is a torque wrench and not a gun magazine. It requires an accurate spec.
Old May 18, 2026 | 09:52 AM
MissileDoc's Avatar
MissileDoc
WAY back when I was in the Air Force, our torque wrench specific technical order stated not to use the lower 20 percent of any torque wrench as that part of the range wasn't accurate.
Old May 18, 2026 | 10:21 AM
rtv900's Avatar
rtv900
likely nothing but people will be adamant that there is
The material property of a spring in compression is torsion, and obviously the wrench won't let you get anywhere near the yield point.
-So saying leaving it under slight torsion is a problem would be an identical position to saying that if you don't jack your car up on blocks if you park it long term means
that you will ruin your coil springs that it sits on. Because they are partially compressed right?
-Or saying that if you park on un-level ground and your passenger side wheel suspension is compressed up while your driver side is drooping down that means
you will ruin your sway bar because it will be left under slight torsion while parked.
-Now think about your valve springs when you shut down an engine. Numerous ones will end up fully compressed. Some guys park their cars for 6 months.
Obviously someone saying either of those things would be ridiculous. All three examples are leaving the spring rod in torsion under storage.
Am I saying that a measuring device like a torque wrench does NOT need calibration. . . . .absolutely not. Two totally different issues.
Old May 18, 2026 | 05:11 PM
kodpkd's Avatar
kodpkd
Most torque wrenches are only correct at one reading. It's nice to be able to check the correct torque. I have a wrench that has a max setting of 120 lb. ft. So I set the 60 lb reading at 60 lb's. I then checked the 20 lb. reading, it's a bit below 20 lbs. and the higher readings are a bit above the set readings. Now I know which way to adjust the upper and lower readings when setting the correct torque.
Old May 18, 2026 | 06:25 PM
rtv900's Avatar
rtv900
Originally Posted by kodpkd
Most torque wrenches are only correct at one reading. It's nice to be able to check the correct torque. I have a wrench that has a max setting of 120 lb. ft. So I set the 60 lb reading at 60 lb's. I then checked the 20 lb. reading, it's a bit below 20 lbs. and the higher readings are a bit above the set readings. Now I know to which way to adjust the upper and lower readings when setting the correct torque.
right
I have one that tops out at 250 and I actually just went to buy a smaller one for exactly what you described earlier. I needed 20 foot pounds for the stupid oil filter housing on my porsche where they use the annoying German style housing where you put the filter element inside it and re-use the housing for eternity. I knew as soon as I grabbed that wrench that the 20 ft/lb setting was probably painfully inaccurate being at the bottom end of the scale. It's good for wheel torque at 100-120.
In reality the old school ones with the little needle where the wrench literally flexes under torque are probably more accurate if they're a quality made one and not a harbor freight deluxe.
Old May 19, 2026 | 08:43 AM
kodpkd's Avatar
kodpkd
But without testing your torque wrench, you don't know if any of the readings are correct. The three wrenches I tested averaged 3.5 lbs off.
This is about if someone needs their torque wrench calibrated.
Old Today | 08:22 AM
Tinkertech's Avatar
Tinkertech
PSA:
Always 'click' it before using it at the desired torque, both directions.
Old Today | 09:07 AM
Macleod52's Avatar
Macleod52
Which calibration tool did you get and where are you going to send the torque wrench to get calibrated?
Old Today | 05:47 PM
SouthernSon's Avatar
SouthernSon
Snap on provides a sheet of actual calibration at the various settings with their torque wrenches. And yes, you pay a lot for that little slip of paper. And you can bet your left nut that I back off the torque each time I put it up as recommended. Also, I don't use it in 'lefty loosey'. If I need to back off a nut I use a regular wrench. I now have 6 torque wrenches of varying capacities. Had to buy one last month at HF to use on 250# nut on tractor. The least one is the Snap On for inch pounds such as rifle scope mounting and other various little specs.
Old Today | 06:39 PM
old stingray's Avatar
old stingray
To Torque wrench
