PTM settings for race course setup
well
well
All the other variations you describe limit traction control in some way....
Not something you want with 670hp, particularly on PS4S, on your first day out...
I just ran my first track day in a 26 Z07 on PS4S, it was a bit of a "handful"....
The Z07 is looking for Cup2R levels of grip...
My history is 100's of track days in Porsche GT cars, I run in the fastest groups, below instructor...
I think a Pro level driver could easily manage this, I have seen some great drives at Sebring on PS4S, but well above my job grade...
YMMV
Cheers!
The PTM modes are Wet, Dry, Sport, Race 1, Race 2, and now Pro. Pro in the non "X" cars, is essentially everything off. Note that the last 3 (Race 1, 2, and Pro) turn off all Stability Control and only leaves traction management on. I would absolutely not start with ESC off the first time out in this car unless you are an advanced level driver. No offense to the OP but "I've driven on a course years ago" does not scream advanced driver to me. The good news is, you can change it in-session very easily. I strongly recommend you start in dry. If you have any reasonable pace, it will interfere too much. If you know what it is interfering and how to correct it, it is time to go to Sport. As beginning to intermediate driver, Sport is probably a great place to be. Are there some corners it really interferes with on some tracks? Absolutely. Does it hold an advanced driver back some? Also, yes, for sure. But with ESC on, it is still way safer, and I would suspect an intermediate driver is not losing much time in a trade of. An Advance driver is going to want Race 1, 2 or Pro depending upon the driver, track, weather, etc. But there is zero reason to start there first time out in the car and not having been on track for "years".
Start in Dry. Graduate to Sport when ready. After you have some seat time in the car, and know what it is doing, it might be time to try Race 1, as long as you understand there is nothing to save you there from spinning or more. (I've spun in Sport as well, so as we know, ESC is not going to save you from every problem).
To add to this PTM modes (everything above Wet) also changes the e-diff. modes, which are ONLY unlocked in the PTM modes. This e-diff. mode helps you get around corners quicker. I believe it loosens up the lockup point, as having an open diff. is actually a benefit when trying to get around a corner. You notice this the most in the lower speed tight corners rather than the high speed sweepers though.
Rather than locking up so soon, which locks the TQ on both side for traction, but also causes the rear to step out if you break traction, while in the more open diff. setting it allows the left and right side tire to work more independently and allow the difference speeds that each wheels sees as you are navigating the tighter corners. It might even over drive one wheel more than the other, but I am not sure if that is true. What I do know is that you can take right corners quicker without the rear stepping out in the PTM modes because of this different e-diff. setting.
When you come from the Porsche world, you basically have TC/ESC on or off....
For tires, if you follow the MVEZ Clubsport threads he is dong a lot of experimenting and has some great tire recommendations.
For me I am awaiting the Hoosier TAP, which should be available soon in our sizes...
Cheers!
Cheers!
https://apexwheels.com/vehicles/chev...e=19x1325-et30
https://philstireservice.com/product/vitour-p1-x-01r/
