I recently built a 383 with my son and installed a Holley double pumper. The carb idles well in park, but when I put the car into drive it wants to stall. If I adjust the carb to not stall it idles too high. I really not that familiar with double pumpers.
The carb is a Holley avenger 770 CFM, I still need to adjust the mixture with a vacuum gauge, but the car runs great for a out of the box carb.
Any tips on where to start. Thanks
I'm not familiar with that carburetor but on my Holley 600 street warrior the first thing I did was adjust the float levels. The next thing I did was adjust the idle mixture. The next thing I did was adjust the idle speed.
Move your vacuum advance hose from the ported position on the primary metering block to the manifold vacuum port on the throttle body front.
Also you have to check float level. Adjust mixture screws in Drive, parking brake on, wheels chocked.
Also you have to check float level and adjust mixture screws in Drive, parking brake on, wheels chocked.
I set the float levels will do the mixture screws later tonight
Since it's an automatic and you are placing a load on the engine when it's in drive you will get a properly adjusted idle. Look at the factory emissions sticker or the factory manual if you want confirmation.
How do you adjust a manual transmission car idling in gear?
Have a friend put the car into 1st and cut the wheel all the way to the left. Slowly doing donuts in an empty parking lot you can adjust your idle mixture, just watch your feet.
I looked at the emissions sticker and my factory manual and can't find anywhere where it states to adjust the float level with the car idling in gear. I can't even find any mention of floats in my factory service manual.
For me adding an aftermarket carburetor I would follow the manufacturers instructions for setting the float level.
I thought you had to turn to the right due to centripetal acceleration forcing the gas to be not level...
Questions:
How big is the cam? Specs?
What is your vacuum reading both at idle? and In gear?
For an automatic, in gear, with a moderately big cam, you are going to have to get both the ignition curve and the carb tuning "just right"
Some automatics do run better with ported vac advance. But most are better with manifold vac. It depends on my two questions.
Start with the above vacuum reading(s).
Then set up the ignition curve, and the vac can.
Then do the carb.
There is an old adage that is still true:
"Most perceived carb problems are really ignition problems"
JT
I never said floats, the idle mixture screws on an automatic
