C8 ERay/GSX/ZR1X ERay/GSX/ZR1X Discussion
Sponsored by: Vibe Motorsports
No front radiator on 27 GSX
Old May 19, 2026 | 04:24 PM
davelv's Avatar
davelv
Default No front radiator on 27 GSX
Just FYI the front center radiator was removed to reduce heating of frunk.
Old May 19, 2026 | 07:20 PM
BGT3's Avatar
BGT3
5th Gear
I believe the side radiators have thicker cores so the cooling capacity was not reduced.
Old May 19, 2026 | 11:57 PM
24/Eray's Avatar
24/Eray
Yep. Got us E-Ray owners good on that one for sure.
But. I also read that because the GS-X is a "1 2 or 3LT" model it won't come standard with HUD not fan you get the high end carbon fiber steering wheel or appointments? Crazy. Should've left the qidebody cars as LZ not LT.
Old May 20, 2026 | 05:59 AM
BuckySti's Avatar
BuckySti
I haven’t noticed things getting too hot in the frunk on the ERay. I’m assuming it still doesn’t get as warm as the trunk?
Old May 20, 2026 | 06:27 AM
Joe's Eray's Avatar
Joe's Eray
Old May 20, 2026 | 07:40 AM
javenius's Avatar
javenius
I asked about this at the Bash and was told they learned a lot with the Eray and found they over-engineered the Eray and they didn't need the center unit. Saved a bit of weight too.
Old May 20, 2026 | 09:15 AM
davelv's Avatar
davelv
What I saw on a recording of a Bash presentation was they listened to owners dislike of the extra heat so redesigned to remove center and made side front radiators deeper to account for bigger engine and larger electric motor.
Old May 20, 2026 | 02:33 PM
LS1LT1's Avatar
LS1LT1
I still believe that the base (1LT) Grand Sport-X will come standard with HUD.
And that only the base (1LT) Grand Sport will not have it.
Old May 20, 2026 | 05:01 PM
davelv's Avatar
davelv
HUD is no unless base is labelled 1LZ on the GSX. No 1LT has ever had a HUD.
Old May 20, 2026 | 05:54 PM
Tonylmiller's Avatar
Tonylmiller
Just curious if you have any evidence of this, or just hopeful? By the way, nothing wrong with being hopeful.
Either way, I'm glad I bought a 1LZ E-Ray.
Old May 20, 2026 | 11:51 PM
LS1LT1's Avatar
LS1LT1
No evidence, but I saw it in the preliminary print when the Grand Sport-X information was first released. Plus, as you already know, the base (1LZ) E-Ray did in fact come with HUD as standard. Not sure why this whole ‘1LT versus 1LZ thing’ should even matter, they are both still standard/base packages. If it was standard in a 1LZ then of course it could still also be standard in the 1LT package of what is essentially the same car (E-Ray and Grand Sport-X) with some new updates.
And I am definitely not hopeful for it, I actually do not like or want HUD and am considering a Grand Sport-X, so I will be thankful if it is not standard.
Old Yesterday | 08:03 AM
G352C6's Avatar
G352C6
Because that is how it is. I understand the frustration, but GM makes the rules; take it or leave it. The same logic that applies to the LT vs LZ distinction is also at play here with the availability of the carbon fiber steering wheel.
To No front radiator on 27 GSX
