Derale Electric fan knocking at start-up
Old May 20, 2026 | 02:56 PM
Dins74's Avatar
Dins74
Default Derale Electric fan knocking at start-up
I have not had time to tear into this yet. But, my Derale electric fan is starting to knock, multiple times and real loud, when the thermostat temp relay tuns it on. Once on it works fine. I used to hear just a slight click when driving. It let me know the fan was turning on. Now I am getting three to four loud knocks before the fan turns on and then it works fine, nice and quite. I have the temp relay set for about 160 deg. It is cooling a 454 w/ A/C. The fan can keep it between 190 to 200 deg. even in traffic.
I was going to direct wire the fan to the battery to try to determine if it is the relay or is the fan going. Just looking to see if anybody else has dealt with this.
Old May 20, 2026 | 03:42 PM
kanvasman's Avatar
kanvasman
check to see if a blade is bent and hitting something. I had that issue on a car once exactly as you described. Once it ran a little it was fine. It ended up the temp heated up either the fan or the shroud and the noise would stop. It ended up being a bent blade.
Old May 20, 2026 | 11:05 PM
augiedoggy's Avatar
augiedoggy
I had this and found one of the fan motor mounts was broken and the fan moved upon startup.
Old May 21, 2026 | 02:52 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'd say, spin that blade by hand with everything turned off. Any knocking? I had one with a bad bearing. It didn't end well.
Old May 21, 2026 | 10:34 PM
augiedoggy's Avatar
augiedoggy
In my case the fan spun fine by hand but when it was powered on the inertia of it starting caused it to momentarily shift and make a noise. one of the plastic spokes that holds the motor was cracked.
Old May 23, 2026 | 12:01 PM
Dins74's Avatar
Dins74
augidoggie, my man, you are the winner! When I went down to garage ooozing with testosterone, hot coffee, and my trouble shooting matrix going through my mind, the first thing I discovered was the upper, right fan mounting bolt was missing. As you described, the fan mount must have been smacking the shroud at start-up. I replaced the bolt and my nice quite fan was back.
Thanks for the responses
Dins74
To Derale Electric fan knocking at start-up
