Ignition shielding
Old May 21, 2026 | 12:21 PM
motionfan's Avatar
motionfan
Default Ignition shielding
This is all I have for the shielding from my 71 350. Im sure it’s incomplete, other wise not in too bad of shape. I think the orange brackets are also for that? If not, can someone tell me what they’re for. Thanks,
Old May 21, 2026 | 01:52 PM
Alan 71's Avatar
Alan 71
Yes.
The top holes of the brackets have a nut tacked in place that captures a wing nut that holds the distributor shield and vertical wire shields in place.
Regards...
Typical for 71 base engine right -side:
Ignition shielding (Distributor, vertical wire shield, 1 pc horizontal wire shield)
Spark plug heat shields (2 per side)
Spark plug wire exhaust heat shield. (1 per side)
Various brackets, bolts and wing nuts.
Old May 21, 2026 | 01:54 PM
motionfan's Avatar
motionfan
Originally Posted by Alan 71
Yes.
The top holesof the brackets has a nut tacked in place that captures a wing nut that holds the distributor shield and vertical wire shields in place.
Regards...
thanks!
Old May 21, 2026 | 10:20 PM
Bills17n72's Avatar
Bills17n72
Old May 22, 2026 | 07:52 AM
motionfan's Avatar
motionfan
Beautiful set!
Old Today | 10:30 AM
Danadell's Avatar
Danadell
Cruising
Good morning. Is the set still available?
Old Today | 11:08 AM
motionfan's Avatar
motionfan
Thats not my set. I had listed only the partial set I have.
To Ignition shielding
