Distributor Not Seating
A long handle flat screw driver can be used to turn the pump shat so it aligns with coupler on distributor gear.
Also note the you have will have start installing with the rotor slightly retarded from where you want it to finish when fully seated, as the gears will cause it to rotate when installing.
It would be essential, as a start, to reseach many of the existing video's on the entire process on setting top dead center (TDC) on #1 cylinder on a 350 engine, as already mentioned.
However from my recent experience, you will have to know and be sure that you are on TDC #1 Cylinder "On The Compression Stroke" on piston #1. I assure you that getting this absolutely correct will save you alot of time and effort as this is required before you even get to the distributer / rotor step. To ensure that I was on the compression stroke on #1 piston, I removed the #1 spark plug had a camera bore scope to see inside the block and watch the piston progress upwards as I was turning the crank bolt with a "flex head long bar ratchet" slowly by hand. Once I saw that the piston was going upward close to the top (this confiirmed to me that I was on the compression stroke). I then finally aligned the timing mark with the mark on harmonic balancer to achieve TDC.
Some of the videos show only how to achive top dead center (TDC) with the cylinder heads already removed from the block.
Note 1 - I did remove my driver side valve cover earlier on as a double check to ensure that I was on the compression stroke, but looking back now, it wasn't required.
Note 2 - A flex head ratchet simplified the TDC process for me as I had limited space to access the crank bolt between my radiator and Vansteel camber brace in which I preferreed not to remove.
https://directlift.ca/ratchet-3-8-dr...eC3ws88C6iq_S_
The distributer step will be the next step in which I'm sure there are videos on the process that likely already exist. Allocate time and extra patience in this procedure.
I hope this helps.
I hope this helps.
^^^^^^^ You may have got lucky (50% chance) or you are leaving something out but the description above does not guarantee you are on the compression stroke. You could have just as likely been on the exhaust stroke. Feeling for compression with your thumb/finger blocking the spark plug hole on #1 indicates the right stroke, not a borescope unless it also tells you both valves are closed.
I had the driver side valve cover removed, which proved to me by the position of the intake/exhaust valves on #1 that I was on the compression stroke. "Feeling for compression with your thumb/finger blocking the spark plug hole on #1 indicates the right stroke" certainly is another way of confirming compression stroke, but that's not what I did as I was posting from my direct experience which was successful. Likely, there are other way to confirm the compression stroke too.
My intention here is not to rewrite the complete GM procedure manual here or replace some great and informative videos already in existance. My intention is to share from my experience on what I did and add some beneficial information to this thread. In my opinion, your comment does add value and information to this thread.
There are 4 pairs of pistons that are at TDC simultaneously every 90deg of crankshaft rotation. In an 8 cyl, 90deg V, 4 stroke configuration a cyl fires every 90 deg of crankshaft rotation, so 2 revolutions of the crankshaft for all 8 to fire.
Here's another tid-bit to consider. With common crank-pins in a 90deg V8, the paired cyls reach TDC 90 degrees of crank rotation apart. In the SBC, the right bank reaches TDC 90 deg crank before the left bank. The crank pin cyl parings are 1&2, 3&4, 5&6 and 7&8. 1 fires 90deg after 2, 3 fires 90deg after 4, 5 fires 90 deg after 6. The 7&8 pair is different. 7 fires 450deg after 8. (360 of crank + 90 for the V).
Here's another tid-bit to consider. With common crank-pins in a 90deg V8, the paired cyls reach TDC 90 degrees of crank rotation apart. In the SBC, the right bank reaches TDC 90 deg crank before the left bank. The crank pin cyl parings are 1&2, 3&4, 5&6 and 7&8. 1 fires 90deg after 2, 3 fires 90deg after 2, 5 fires 90 deg after 6. The 7&8 pair is different. 8 fires 270deg after 7.
If spark plug hole one (or cyl 1) is under compression at the time the harmonic balancer indicator is at the 0 degree mark, it's safe to say that piston #1 is at TDC, and is an OK location for her to re-install the distributor with it pointing to the #1 spark plug wire location on the distributor cap, correct?
We were trying to turn the crank with a socket wrench, and instead, my daughter had the idea to stuff a silicone plug into the spark plug hole, and then slowly crank the engine using the starter. All of a sudden, we heard a crazy pop, and the silicone plug was sent flying across the room. We looked at the balancer, and it was perfectly on the 0 mark.
We installed the distributor back, and it's maybe a few teeth off. So, we'll take it off again and spin the rotor over a few so I can get it back to where it needs to be. Ugh... haha...
https://www.amazon.com/LVOUP-Engine-...9798023&sr=8-4
