2016 Chrome Wheel Repair
Old Yesterday | 11:02 AM
jwatty's Avatar
jwatty
Default 2016 Chrome Wheel Repair
2016 Stingray Z51 rear chrome wheel has slow leak after installation of new tires. Tire store says it is a defect in the chrome plating and needs a new wheel. Looking for feedback on options to repair rather than replace wheel such as have it re-chromed.
Old Yesterday | 11:46 AM
kodpkd's Avatar
kodpkd
I had a leak after new tires were installed. The guy didn't know how to install the TPMS. Did you check the valve stem for leaks with soapy water?
Your car isn't supposed to have cracking wheel issues.
Old Yesterday | 12:18 PM
RonC7's Avatar
RonC7
Look up Alloy Wheel Repair Specialists - there is a franchise location in Jefferson City, TN.
https://www.awrswheelrepair.com/loca...on-City/37760/
They aren't the only wheel repair company, just the one I happened to use in the St. Louis area. They did a perfect job straightening a bent rear chrome wheel on my GS. They claim to be able to repair or remanufacture almost any wheel.
GL
Ron
Old Yesterday | 02:51 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
As mentioned, check for a loose nut holding the TPMS assembly in place and also a loose valve core.
Don't over tighten them, just finger snug.
Old Yesterday | 06:13 PM
C5FORFUN2's Avatar
C5FORFUN2
The chrome isn't what holds the air in. It's possible the aluminum has corroded and become porous.
Old Yesterday | 07:10 PM
jwatty's Avatar
jwatty
Yes, checked and replaced valve stem, small air bubble in one place around the rim. Thanks for the reply.
Old Yesterday | 07:12 PM
jwatty's Avatar
jwatty
Yes, you are correct, that is what they said it was the aluminum. Thanks for the reply.
Old Yesterday | 07:13 PM
jwatty's Avatar
jwatty
Thanks for the info on the vendor.
Old Today | 10:12 AM
kodpkd's Avatar
kodpkd
Did you replace the entire TPMS for that wheel? You said, "small air bubbles in one place". Is that around the rim of the valve stem? That's what I had after the, tire store, screwed mine up.
To 2016 Chrome Wheel Repair
