Window Fuzzy Installation
1. The door window weather strip has split buttons that need a touch of lube and pre squeezed before install.
2. Dont install the rear track until the glass is on the regulator rails.
3. Each of these strips are fragile and expensive.
Now the question remains, which side of the weather strip faces in. The small or large molding trim.
The small trim is shown towards the top of pic. This one fell apart out of the packaging. I understand these can be had in two pieces. the rail with trim and the fuzzy.
Cheers
https://www.corvetteforum.com/forums...ner-coupe.html
From Corvette Central back in the day.
