[C2] Spare tire size
DennisAI Overview
As a prominent Corvette Forum expert, JohnZ (John Hinckley) noted that a 1990s-era Chevy S-10 compact temporary spare wheel (T155/90D-16) perfectly fits the C2 Corvette. It has the correct \(5 \times 4.75"\) bolt pattern and clears the C2's disc brake calipers without rubbing.
[[url=https://www.corvetteforum.com/forums/c1-and-c2-corvettes/2094442-63-67-spare-tire-tub.html]1, 2, 3]
Context & Fitment Details
- The Spare Tire: The S-10 compact spare is a 16-inch wheel with a smaller outer diameter tire. Because of this, it is the only viable spare that fits neatly inside the C2's stock spare tire tub under the rear, as modern full-size radials will not fit.
- Full-Size S-10 Rims: If you are asking about fitting standard driving tires/rims from a Chevy S-10 onto a C2, you should avoid using them. While the 5-lug bolt pattern (\(5 \times 4.75"\)) is technically the same, S-10 wheels (like stock 15-inch S-10 Rallys) generally feature a front-drive offset or deeper backspacing designed for a truck. They will cause severe rubbing on your C2's control arms and frame.
- Recommended C2 Sizes: For regular street driving, JohnZ and other forum members recommend sticking to a 205/75R-15 or 215/70R-15 radial tire mounted on factory C2 wheels to prevent cracking or rubbing your fiberglass fenders.
- [[url=https://www.speedwaymotors.com/shop/wheels-corvette-c2~8454286-1-949-17-601-7644-45] 1, 2, 3, 4, 5, 6, 7, 8, 9, 10]
To fit a spare in a C2 Corvette, use a 15" x 6" Kelsey Hayes wheel (either an original finned knock-off or a standard steel wheel). Pair it with a \(6.70 \times 15\) bias-ply tire (the modern equivalent is a 205/75R15), and inflate it to no more than 26-28 PSI so the spare tub closes properly. [1, 2, 3]
Key Spare Tire Guidelines
- Wheel: The original 15x6 Kelsey Hayes knock-off or a standard steel Corvette wheel. Wider wheels (like the 15x7 or 15x8s used on the ground) will not fit in the under-car spare tire carrier.
- Tire Size: A 205/75R15 is the ideal modern radial replacement for the original bias-ply size. Today's radial tires have thicker sidewalls than the originals, making a 205/75R15 a tight fit in the fiberglass spare tub.
- Inflation: Keep the spare deflated slightly to roughly 26 PSI when storing it. This prevents the tire from bulging and rubbing against the carrier hardware or the exhaust.
