C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Z06 - Headers, CIA and FlexFuel - Stock Fuel System
Old May 26, 2026 | 10:29 AM
C7&7's Avatar
C7&7
Default Z06 - Headers, CIA and FlexFuel - Stock Fuel System
Anyone out there running full e85 with cold air, headers and a tune obviously on a completely factory fuel system? I know it's possible to run full e85 with a cold air, but anyone add headers and able to run full E?
Old Jun 3, 2026 | 11:00 AM
R3DRUM's Avatar
R3DRUM
I run this exact setup. Zr1/19'Z06 pump will max out around ~70% Ethanol, The ethanol around me usually tests at ~63% or so I run full pump E. In Houston, I had to blend a little bit because some places would test at ~80%.
Old Yesterday | 01:32 AM
C7&7's Avatar
C7&7
Great information thank you. My Z06 is a 17, so I'd probably need to through a low side fuel system in the mix.
Old Yesterday | 08:10 AM
R3DRUM's Avatar
R3DRUM
If you wanted to run full E yes. The factory lowside on pre '19 MY should carry you to E30-50 depending on where you live.
Old Yesterday | 08:24 AM
C7&7's Avatar
C7&7
Yea I don’t want to worry about knowing the E content. It’s great to know that the high side can handle it without meth or a cam.
To Z06 - Headers, CIA and FlexFuel - Stock Fuel System
