C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Messed up and put in regular gas
Old May 26, 2026 | 05:04 PM
ATXKnights's Avatar
ATXKnights
3rd Gear
Default Messed up and put in regular gas
I had over a half a tank of premium and filled it up at a different Chevron and chose regular by accident. Any thoughts on how to proceed? Should I add some Octane boost or just drive it and keep topping off after a quarter tank is gone?
thanks
Old May 26, 2026 | 05:25 PM
minuteman71's Avatar
minuteman71
thanks
My opinion only--The ECU will retard timing so there will be no knock. Gas mileage will suffer 2-4%. I would not drive aggressively but around and about use most of the gas up and then fill with super.
Old May 26, 2026 | 05:27 PM
lgodom's Avatar
lgodom
I think your idea of adding an octane booster would be what I’d do. If premium is 93 where you are and you add a half tank of 87, you’re only down to about 90 octane, which is only 1 point under areas that have 91 octane. You’re probably ok either way
Old May 26, 2026 | 06:15 PM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Don't use octane booster, the owner's manual specifically prohibits doing so (i.e. could void warranty). And yes, there will be visible proof as it leaves a colored tint on plugs and other combustion chamber internals. As others have stated, it'll adjust just fine as you're probably about 90 octane. Even if you filled the entire tank with 87, it would still run fine as the computer will pull timing to protect it. If you want to be extra safe, top off with 93 as soon as you use about 1/4 tank.
Old May 26, 2026 | 07:07 PM
AzDave47's Avatar
AzDave47
If it was half 93 and you added 87, just don't go full throttle. If it was 91 and you added 87, I would suggest keeping it at modest throttle and under 3K RPM until you are able to get more 91 in it. Maybe there is somewhere near where you are (racetrack maybe) that has 100 octane unleaded and you could add that in when you have 3/4 full, then you would be good to go normally. As indicated above the OM says no octane boosting additives and having used some on my modded no cats LS7 C6Z, they do leave an orange residue on the spark plugs.
Old May 26, 2026 | 07:23 PM
FoundNemo's Avatar
FoundNemo
Put it in weather mode and coast around. Will be fine. Once low, fill on 93 and resume party. No octane boosters. Any that have the MMT will turn plugs and such orange and bye bye warranty
Old May 26, 2026 | 07:33 PM
CGGS's Avatar
CGGS
You are fine. The performance will be a little less, but the ECU can adjust , especially for just 1 tank.
Just be glad you didn't accidentally fill up w/ diesel, that would be something else entirely
Old May 26, 2026 | 08:09 PM
Rapid One's Avatar
Rapid One
Do nothing unless you hear knocking. Keep topping it off with premium.
Old May 26, 2026 | 08:16 PM
patton's Avatar
patton
St. Jude Donor '09
drive it till an eighth of a tank then high test .....no drama if ya drive it out besides they burn fuel rather quickly
Old Yesterday | 08:49 AM
Zjoe6's Avatar
Zjoe6
Just run it out and don't get on it.
Old Yesterday | 08:55 AM
68Malibu383's Avatar
68Malibu383
Sell the car immediately.
Just drive it easy and everything will be fine.
Old Yesterday | 09:02 AM
QuickSilver20's Avatar
QuickSilver20
I wouldn’t worry about it. I would just not run it too hard until you can refill with premium to avoid knocking. Although a lot of cars say premium is recommended/ required manufacturers know that people will ignore it so they have built in safety guards. You may experience less the peak performance or knock but the engine will be fine.
Old Yesterday | 09:51 AM
Garret's Avatar
Garret
I believe in the Beer Fairy
First world problems...it does not matter...it won't hurt the car...no matter what the stickers say. lol...I figured this was just like the humorous threads like the oh no, I left my car in the rain threads...
Old Yesterday | 11:25 AM
DVC8's Avatar
DVC8
Shouldn't take you long to burn thru that tank of fuel....my Z06 lives at the gas station compared to my C8 Stingray! I'm lucky if a full tank lasts me 250 miles!
Old Yesterday | 12:27 PM
EvanZR1's Avatar
EvanZR1
I don't even break into the 200s per tank unless I'm highway cruising on a trip.
Old Yesterday | 01:17 PM
chevyvette1's Avatar
chevyvette1
[QUOTE I'm lucky if a full tank lasts me 250 miles![/QUOTE]
I would be so excited to get 250 a tank lol... I'm happy when I fill up and I break 200 miles of range
Old Yesterday | 02:14 PM
Retired2024!'s Avatar
Retired2024!
I would be so excited to get 250 a tank lol... I'm happy when I fill up and I break 200 miles of range [/QUOTE]
If you bought the ZO6 with concerns of gas mileage……..you drove past the Toyota dealership and forgot your Prius there.
LOL
OP. I would drive it easy until it hits 1/4. Then fill it up with 93. Finish that tank easy. Then resume regular warp speed operations!
To Messed up and put in regular gas
Old Yesterday | 08:06 PM
WillTWallace's Avatar
WillTWallace
Professional Beginner
Spot on. There is not a single legal team, of any billion dollar automotive company, that would allow a vehicle to be on the street that would fail mechanically if a consumer selected a different grade of fuel.
I have owned high performance cars for many many years. YES, a few are tuned specifically for 93 and some higher...but they are mechanically sound without. yes, as noted, performance level may decrease, but, it will be fine.
Now, this is coming from the guy who will not fill up at a shady, tobacco shop style, dimly lit store, surround by iron bars that sells fire wood, cheeseburgers, puppies, and gas.
Old Yesterday | 09:08 PM
C83LZ's Avatar
C83LZ
You’re fine just don’t push it hard and fill it up at half way and again….from there you should be getting close to 91 and then 93 octane if you have it.
Old Today | 11:04 AM
Gullwaydad's Avatar
Gullwaydad
Hate to say it, but I did the same thing about a year ago on my '24 Z. Ran it down to1/2 a couple of times didn't run hard. Never a problem and today I can't tell I ever messed up. Enjoy and don't worry.
