Can't Find My Timing Issue
Checked timing multiple times, re stabbed the distributor twice to be sure. Also verified all the plug wires were in the right place. Installed new plugs as well. It will not run smoothly with all the vacuum ports connected. It wants a ton of air. I am looking to pull heads next to verify what I saw with the scope. I am totally at a loss. I showed the gear to a mechanic friend and he said it looked like a bad heat treat that finally failed. There is nothing that I can feel or see that is impeding the rotation of the motor. Something is damaged, it could well be the lifter, but other than putting in a new lifter, how do I verify that the lifter is good? Have any of you had a similar thing happen to them? Any help would be greatly appreciated.
Or do a compressions test.
The intake valves look pretty straight. Lots of carbon, but straight. I think I am gonna add a catch can to the pcv line. It's pulling a lot of oil.
Last edited by Drawmain; May 26, 2026 at 07:44 PM. Reason: Added results of inspection of valves
Something is wrong in that cylinder.
Without pulling heads, I would check cranking compression, and leak-down, and report back.
Buy a ~$100 leak down gauge, it is much better than compression. But if your compression is not good, you already know.
Valves may look seated, but you could have bent one. That would explain the sticking #4 too.
Hopefully it is just a bad sticking lifter.
Was this a metal crank gear that sheared off teeth? or the OEM plastic tooth one?
It was a metal crank gear that failed, snapped the chain as well.
Start with the basics. Confirm what's good. Then move on.
Something bad happened inside to snap a timing chain and a metal crank gear.
