Value of 1969 C3 Stingray 427
Old Jun 1, 2026 | 02:46 PM
69Sting427's Avatar
69Sting427
3rd Gear
Hello all,
I am a first time poster here, you all have a great community. I am a part of a couple other car forums and always enjoy the conversations on them. Forgive me if this kind of post is not allowed, I will happily post it somewhere else or remove it.
My grandfather bought a 69 corvette in the 70s/80s. He died in 1986 and it has sat in my grandmas climate controlled basement since then (it was running when he died). She passed away about 5 years ago and my dad and uncle don't know what to do with the car. I'd like to buy it from them, but I'm trying to figure out the value of it. I'm hoping I can get the VIN off of it soon, but I believe it's either an L68 or an L71. It does not have original paint, I know he took the 3 2s off it and put a 4 barrel on, and it's undetermined if the original carbs are in the basement. Obviously the motor will need to be gone through, new tires, etc. I am trying to figure out the value of it as it stands. Any help would be much appreciated.
Thank you in advance
Hello all,
My apologies on the pics, I hope to get them soon. The fiberglass is in good condition. No wrecks.
Old Jun 1, 2026 | 03:16 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
You can go on Hagerty and get a good estimation of value there....they divide it up by condition as well as options
Old Jun 1, 2026 | 03:33 PM
Hopper12's Avatar
Hopper12
Hi, and welcome! This type of post is definitely allowed and there are plenty of great members here who can help you figure it out. Here are some thoughts/questions to get you started on the help you need.
  • Picture of the engine stamp on the front of the block on the passenger side - just in front of the bottom of the head. Be careful not to remove more than grease away as you don't want to score the broach marks on the pad - don't make the mistake of scraping it - let's see what you have before going any farther. The pad will have two strings of identifiers - one that includes the engine suffix (tells you which engine you have) and date code; the other will be the partial VIN. Having the pad VIN match the car VIN is a very good thing, especially on an L68 or L71.
  • Picture of the VIN - you can take it of the A pillar on the drivers side through the windshield.
  • Picture of the data plate in the drivers door jam.
  • Trans type
  • Pics of the car, inside, out and under.
  • Mileage if known
  • How long since it's been driven. If it's been a long time (sounds like it has) it will need complete brakes, fuel system work, tires, etc. That's okay and we can help you through all that.
  • If it's a tripower engine suffix that is original to the car, can you find the intake and carbs. If so, get us pics of the intake and carbs - the carbs can be rebuilt (do NOT send them to Holley - we can guide you).
  • A bit about you - your mechanical skills and do you have some $ to see it through.
The above will get us started on helping you. This could be a really cool car and opportunity to keep your family history going with the car - makes it that much more fun.
Best, Paul
Old Jun 1, 2026 | 03:52 PM
Tampa Jerry's Avatar
Tampa Jerry
I hope you get it. Sounds like a fun project. If you do, be mindful that if you change out the fuel tank and it's the original one, there should be a data sheet glued to the top of the tank. It will tell you what options, engine, etc that the car came with from the factory. Ask your dad and uncle if there is any paperwork on the car. It could be a treasure trove of information. Good luck. Jerry
Old Jun 1, 2026 | 06:54 PM
kanvasman's Avatar
kanvasman
the best thing I could think of is to ask them what they want for it. They can do their homework and come up with a number, you do yours ad then split the difference. Everyone is happy...por at least no one is mad.
Old Jun 1, 2026 | 09:06 PM
socal_tom's Avatar
socal_tom
It's very simple the value is as much as someone will give you . Hagerty has stated value of 60K on my car and if someone offered me 60K it's there car
Old Jun 2, 2026 | 07:03 AM
Johnny Andrew's Avatar
Johnny Andrew
7th Gear
Originally Posted by 69Sting427
Hello all,
Hello all,
****** Welcome and sorry for your loss. Based on your description, if the garaged car is largely original (except for the exterior paint), an L68 is probably worth around $60K and an L71 is probably worth north of $75K. If the vehicle has matching numbers, you're probably looking at $35K to $75K in additional value especially if it's nice driver quality. Hopefully you get it because if you do it will certainly stay in the family. If they don't want to let it go it's probably due to the sentimental value of the Vette. Most of the Vette & Mustang Club members I chat with talk about the history of their classic which almost always has an emotional connection to someone or something in their past lives. If you get it, restore it and keep it in the family. Good luck!
Old Jun 2, 2026 | 11:13 AM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Hasn't moved in 40 years, it's going to need everything! Provide photos and exact details, including VIN and folks here can help more, but sitting so long it's significantly devalued IMO....
Old Today | 11:57 AM
Tinkerah's Avatar
Tinkerah
I respectfully disagree that it will need "everything". The running gear in particular, stored in a climate controlled space will not have aged significantly. Anything that had fuel in it will need to be thoroughly cleaned but the motor and driveline only need to be checked for oil levels (if there aren't any oil spills under the car I'd wager they're fine) and brought back into motion gently. The brakes are notorious for acting badly when not being used, and of course tires that old should only be used for carefully maneuvering around the property.
You've come to the right place, congratulations!
To Value of 1969 C3 Stingray 427
