Friends - my driver side arm rest broke off on the left end. I ordered a c3 armrest repair kit but the instructions are too vague. Has. None had to reattach using the repair kit? If so please take md through the steps. Or if you can suggest an as alternative attachment method please do. Thanks in vance
And perhaps what car your working on? My C3 arm rest is a part of the door panel. I have a 77 model.
If your car is a 78 or newer. It's totally different.
Great post and even I did not know there was a difference between the 77 and my 78???
In any case I've had nothing but problems with my 78 since I've had it so now I just open and close mine with the window down
And if any one of the C3 gurus can shed some light on it pls reach back out
I do know that the upper handle bolt always pulls away from the door panel and that the panel has to be removed etc which at my tender age of 80 is beyond my capabilites "so there just has to be a better way to do a permanent fix"!!!
FWIW one of my club buddies said to try a longer-larger diameter screw????
JJ78
What year and exactly what did you order, vendor and part number?
From your picture it looks like you are working on a 1980-81. In that case, the armrest repair kit consist of a metal sleeve, and a large and small screw. The kit is used to repair the front of the armrest, where it pulls away from the door panel. You slide the metal sleeve into the front screw hole of the armrest. The small screw goes into the bottom of front screw hole into a side hole of the sleeve to hold it in place. The large screw then goes thru the front hole of the armrest into the door panel. You reuse your existing screws to secure the back screw holes of the armrest into the door panel.
I assume you have the kit that comes with three parts, a sleeve, a short screw and a long screw. To repair the armrest you insert the sleeve in the hole at the top of the armrest, screw the short screw through the hole in the side of the sleeve to secure the sleeve in the armrest and them reattach the top of the arm rest to the door using the long screw.
I might have a couple of the kits in stock that I think include instructions. I'll take a look in the morning and if they do have instructions, I'll post them here.
Reason: spelling mistake
