Stereo Question
Old Jun 2, 2026 | 08:36 AM
jost6453's Avatar
jost6453
Default Stereo Question
I have ‘10 GS with the BOSE system. There is no AUX port to input music from my phone. I’d like to keep it looking ‘factory’ so would consider replacing the current head unit with one from a newer year. Does anyone know if the head unit from an ‘11-‘13 will plug into my ‘10?
Old Jun 2, 2026 | 09:13 AM
dr_gallup's Avatar
dr_gallup
They will work but you need a Tech II tool or similar to marry them to the electronics. Much better to get a modern aftermarket unit.
Old Jun 2, 2026 | 09:20 AM
FAUEE's Avatar
FAUEE
Assume you have the nav unit? They make adapters that plug in like a satellite radio box in the back that will give you an aux in, Bluetooth, etc.
Old Jun 2, 2026 | 02:23 PM
kanvasman's Avatar
kanvasman
My 2012 has a port inside the center arm rest compartment which I thought was for that purpose. Never tried it since I switched out the HU as soon as I got the car. Not sure about a 2010
Old Jun 2, 2026 | 02:34 PM
EVRGRN's Avatar
EVRGRN
^ Yes, that's the Aux port. I used it to play music from my phone on my 09 non-Bose system car.
Old Jun 2, 2026 | 04:50 PM
jost6453's Avatar
jost6453
Yes, it has navigation. Should have mentioned that initially.
Do you have additional info on the adapters?
Will later years of the nav unit head (‘11 - ‘13) plug into the ‘10 and are they bt compatible or at least have an aux port?
Old Jun 2, 2026 | 07:13 PM
dr_gallup's Avatar
dr_gallup
They will plug in. The Blue Tooth is really limited. It basically just lets you use the phone hands free. You can't play music and of course Android Auto or any other apps don't work. It doesn't even use the phones contact list. They do have the USB port and AUX port.
Old Yesterday | 08:04 AM
Snappahead's Avatar
Snappahead
The aftermarket units work seamlessly in your dash. Other then the manufacturer's logo you won't be able to tell it isn't stock.
Old Yesterday | 10:19 AM
FAUEE's Avatar
FAUEE
Looks like all of the interfaces from isimple and PAC are out of production. There was a GM.one at one point too.
They come up for sale from time to time. It's definitely faster to replace the radio though.
Old Yesterday | 12:42 PM
Pettrix's Avatar
Pettrix
I have a 2013 which had the Bluetooth and AUX ports but it proved to be outdated when trying to play music so I swapped it out with a Kenwood unit. Now I have streaming Pandora and can run WAZE, with hands free phone and can take phone calls and the audio comes through the car speakers. The OEM unit is so outdated, it's not worth the effort to try and do anything with it besides replace it.
Old Yesterday | 04:34 PM
cadbob's Avatar
cadbob
I flashed my Kenwood so it displays C6 Flag and Grand Sport under it.
i saved my oem nav if i sell and someone for some reason wants to go back to stock, did same with all the speakers. Probably take 3 hours tops to re stock system.
Old Today | 09:07 AM
csnow's Avatar
csnow
This is the way. Get rid of the factory junker and store if you're a purist or worry a potential new owner would care. There are way too many benefits replacing vs staying with the "all numbers matching" ideology.
Old Today | 10:51 AM
Landru's Avatar
Landru
Call Crutchfield, they'd know whether or not a fix is available.
To Stereo Question
