Mobil one Supercar 0w-40 vs 0w-50 oil test results
The sample mileage is the actual mileage between oil changes? Both of these Supercar oils shear down in viscosity quickly and then level off. In the case of the 5W-50, new oil out of the bottle tests right at the very bottom of the range for a 50 wt oil. In my last analysis, at 2200 miles the viscosity was solidly in the 40 wt range. The car is a 2023 Z06.
1st we had an oil company formulator who said when it 1st came out he reserved judgment as "viscosity improvers" reduce their effectiveness with miles driven
2nd had a friend who worked at EXXON as their Chief Welding Engineer. Recall he told me they supplied a bottler viscosity improver in truck loads. They filled bottled of STP. They shipped directly to retailers STP was a great marking program but no facility! Love their "Can't Hold A Screw Drive By The Tip Coated with STP.
3rd I started using Mobil 1 in 1974 when it was hard to get and very expensive. The Datsun service rep told be to put it in my two large Hitachi SU variable venturi Carb dash pots! The 1974 260Z was as all cars that year subject to new EPA rules. It was before CATs and mine had an air pump putting air aimed at the exhaust valve in the manifold, they added coolant to the intake manifold to better atomize the lean fuel mixture etc. (Heck the 1974 Vette small block only put out ~200 hp. To get 275 hp had to opt for the 454 big Block!) It was doing what he called "Porpoising" when acceleration rapidly after it warmed up. The Dashpot Oil was losing viscosity and the large piston fluctuating excessively up and down. He said a new oil they were selling to the military in Alaska has a very wide viscosity range It was a man made POA OIL (Polyalphaolefin, a premium, lab-synthesized base fluid used in high-performance synthetic lubricants.) It worked and the 260Z that was not doing what F1 cars were a few years ago. After reading the oil details and very high temperature capability details I started using in in my modified Corvair engine where the oil could get to 325F per the temp gauge I installed. There was a scum in the oil fill pipe soon after changing oil. It was breaking down. Mobil 1, labeled Synthetic, cleared that up!
But Mobil lost a suite to Castrol who was calling their essentially regular oil "Synthetic" saying it was more "highly refined." The article below (few you'll find) said that essentially "dino" oil cost half what POA oil did to produce and Mobil changed! Had to. The price did cut in half. By then no more Corvair but have used Mobil 1 since!
SIDEBAR
Great read in Car & Driver by Patrick Bedard when Mobil lost the suit. Won't find many car mags discussing because oil companies are advertisers.
He starts with "Now that the meaning of "is" has gotten so slippery you need to grab it with both hands, we'd better keep an eye on longer words, too." Referring to the Clinton Lewinsky affair!
https://www.caranddriver.com/feature...antics-column/
