Entry/Exit Ease, Issues, Aids
Getting in the car is not an issue, getting out is.
Basically, I could use a bit of a boost. (C-130 pilots who used RATO will understand).
Currently, I lightly grab the lower corner of the seat back. I'm worried about damaging the seat cover long term.
I have the seat set up to travel all the way back when the door is open. I don't know if raising the seat would help...or whether I can raise the seat without my head hitting the headliner.
I was thinking I could use some sort if a handle there.
Most cars have a door latch loop there, that I could grab, not so the C8.
There were a couple of threads here on this in 2022, one poster recommended a device they sell online that fits into the door latch hoop.
It was pretty clear that guy didn't own a C8 since it wouldn't work because of the rather obvious lack of the latch loop.
I was thinking of making something like those canes with a horizontal handle and four feet...cut it to length of 10-14" (if you were to produce it commercially, the length would have to be adjustable). The key would be the "feet" would have to fold flush...my idea would be to store it between the seat and door while driving.
On my fairly low Mercedes coupe, and my wife's newer Lexus...(which the sloping windscreen and low roof make exiting problematic for someone my height) there is a pivot handle mounted above the door. Likewise, my high SUV has a handle built into the A-pillar.
Any other ideas out there?
The vendor who sells those form fitting engine vent blocks to keep water out of the engine bay is introducing a new product.
Looks like it would work, but I'm kind of balking at the price. ($349).
https://amoracorvettelady.com/shop/ols/products/ease-in
Any other suggestions aside from working on strengthening my legs to do squat thrusts (which I am working on
)?Last edited by JeBC8; Jun 3, 2026 at 10:33 AM.
On my C5, the striker loop is on the body, door opening frame, and I have a handle that fits right into that striker loop, and I can use it to lever myself out of the car.
Although, I have trained myself how to get out of my car now, and haven't used the handle in months, but I do still carry it with me.
Same handle can be used as a hammer to break glass and has a blade to cut the seatbelt for an emergency exit situation.
But, no, it won't work as a handle for the C8.
For getting out I reverse the procedure using my hands to help lift me up out of the seat if necessary.
I have my seat exit position set as far back and as high as possible and the steering wheel fully raised.
I realize this wouldn't help when not at home ... But if you find a solution like the 4 leg cane with a horizontal bar, at least you wouldn't need to use it at home.
)?Getting in the car is not an issue, getting out is.
