[C2] Dropped cylinder
Old Today | 03:16 PM
Charles55's Avatar
Charles55
Default Dropped cylinder
66 327 built to l79 spec with roller cam. Bought as not run in 3-5 years.. motor would run but not at idle, 2500 rpm just to get on trailer. Did timing according to lairs to the letter , I KNOW it’s right. Motor starts right up and dies, need full choke and pumping of gas to run. Did compression test 1-160 3-160 5-160 7-160 2 155 4-155 6-155 8-160 IR on cylinders 1-230 3-550 5-550 7-440 2-400 -443 6-445 8-420 Plug on 1 wet , new plug, no change. New wire, no change. Vacuum at startup 2500 rpm 15”, after warmup can get 1000 rpm ,vacuum at 11. I don’t want to pull intake but thinking I may have internal vacuum leak. Opinions?
Old Today | 03:26 PM
c2vettehead's Avatar
c2vettehead
People also ask
What if wet compression test is higher than dry?
If compression rises significantly (often 40 PSI or more) during the wet test compared to the dry test, it indicates worn or damaged piston rings as the source of compression loss. If there's little or no change in readings, the problem likely lies with the valves, valve seats, or cylinder head gasket.
Old Today | 03:31 PM
c2vettehead
Hyd roller or mech. hyd roller?
Maybe valves/rockers not adjusted right?
Old Today | 03:54 PM
jforb's Avatar
jforb
Exhaust temp indicates 1 is not firing, so maybe pull that valve cover and have a look at the valve train motion?
Old Today | 04:01 PM
Charles55's Avatar
Charles55
I agree not firering, but has good compression.
Old Today | 04:10 PM
acstephenson's Avatar
acstephenson
This isn't a compression problem as the variation isn't significant. My first thought is bad fuel. How long has this thing been sitting? If you didn't flush and clean the fuel system, you're starting it may have been the worst thing you could have done. How does the fuel smell? If it's bad you won't even have to ask. It could be something like a badly leaking brake booster or stuck PCV valve or missing (large) vacuum hose but before doing anything if that fuel is bad get it out of there, replace the fuel pump, rebuild the carburetor, flush the fuel lines, and replace the filter. The fuel sock may be completely gummed up so dropping the tank is probably wise and hope that it hasn't coated the valve stems. You may have a separate ignition problem and my guess with the parts you have replaced is distributor cap.
Old Today | 04:12 PM
Factoid's Avatar
Factoid
You could have a wiped cam lobe on #1 cylinder.
Old Today | 04:48 PM
R66's Avatar
R66
If the plug is wet on #1, you are getting fuel. You have confirmed compression. If you have an induction timing light or in-line tester, check the wire with the engine running. I would test all 8. Then pull the cap and inspect for gray smoke trails indicating a crack or look at the contacts inside and outside of the cap. You can pull the valve cover and check the rocker / valve action, but if you are getting fuel on the plug, it is electrical. Bad gas would effect all cylinders IMHO. What ignition system? Points or electronic?
Old Today | 04:51 PM
Westlotorn's Avatar
Westlotorn
The fastest check would be to pull the valve cover and measure movement on the #1 intake and exhaust valves as they open and close. Compare to cylinder #3 next to it. A flat lobe cam will lose a lot of lift fast. .200 or more is not uncommon but in roller applications it us usually a flat or damaged wheel on that lifter. Best of luck, hope it is a minor set back.
Old Today | 04:54 PM
lucky131969's Avatar
lucky131969
lucky131969
How do you know you have spark at the plug?
Old Today | 05:12 PM
acstephenson
Needs full choke and pumping of gas to run does not sound like a single cylinder problem. If only #1 were missing the engine would not have a problem idling.
To Dropped cylinder
