PTM not std on base GS?
Here is what AI says:
Edit: Now that I see that GM doesn't endorse the base GS for track use I could see GM not wanting to spend the money to develop the PTM parameters for the softer springs and AS tires on the GS. It may only have Competitive Driving mode like the base Stingray.
And here is some more evidence from the news release that not all Grand Sports have PTM:
"Plus, standard Magnetic Ride Control, available Performance Traction Management, and so much more."
PERFORMANCE
TRACTION
MANAGEMENT
The standard Driver Mode Selector allows you to choose from Tour, Sport, Track and Weather modes as well as the customizable MyMode. You can also activate the customizable Z Mode by pressing a button on the steering wheel. The modes affect throttle response, suspension and overall handling for a truly tailored drive.Provides a balanced blend of comfort and performance, ideal for regular city and highway journeys.
Enhances responsiveness for sporty environments, with firmer suspension and more aggressive transmission shifts and steering feel.
Prioritizes performance on closed courses or tracks, allowing for maximum control and speed.
Optimizes the car's performance for slippery conditions like rain or snow by adjusting throttle response and traction control.
A personalized driving profile for everyday use, allowing you to adjust settings like exhaust sound level, steering feel and suspension to your preferences.
A quick-access, driver configurable performance mode allowing drivers to personalize settings like Performance Traction Management, steering feel, engine response, exhaust sound and brake feel to match their preference.
[/QUOTE]
Changes Required
Changing the Michelin® Pilot® Sport All Season 4 275/30ZR20 front and 345/25ZR21 rear, performance, run-flat tires will also change the following:REMOVED
Z52 Sport Performance Package
- Performance Brembo® antilock brakes
- Michelin® Pilot® Sport 4S 275/30ZR20 front and 345/25ZR21 rear, high performance, run-flat summer-only tires
Changes Required
Says so on chevy site i pasted it above. Says STANDARD ELSD. ELSD has PTM. It's hiw it works.
ELSD is standard PTM will be as well.
