I'm having head/cam done on my 2025 E Ray, question about cams
Here is an email I received today.
The camshaft options we typically use in our C8 N/A packages are the Brian Tooley Racing (BTR) Gen V 220 or Gen V 225.
I can google this, but I prefer hearing from someone with experience about the difference between the two. Paraphrasing I was told the V220 was milder and the V225 was a bit wilder. If so, would the V225 be too wild for everyday driving or not. Or is this mild vs wild even correct? My car is basically for the drag races with minimal daily driving. There seems to be a lot of positive comments on Tooley Racing.
E85, launching at 4,000. I'm having head work done, so they might shave off a bit which should increase the compression ratio.
Cam specs for the bigger cam are 225/24? 113lsa. If the question mark turns out to be a "0", the cam's overlap would be 6.5 degrees which most folks would tolerate just fine in a part time streetcar. If the question mark is actually a "9", the cam's overlap would be 11 degrees which is more than I'd want to tolerate driving on the street. Upping the compression ratio would help to tame the cam a bit.
I don't know how much you could mill and how thin you could go on the head gaskets before running into PTV issues. Don't know if fly cutting the pistons is an option on the LT2. Also, if you're limited to 93 octane, that may limit how high you can go. With E85, you can go way up without being octane limited. E cools the intake charge as well as giving more octane. Makes more power two ways.
You already have to remove the engine to do this job. Go with the GPI SS3, Flycut the pistons, Mill .040" off the heads, and run a .040 Head Gasket and tune it on E85. It will drive excellent if your tuner is good at his job and make gobs of power. By just installing a BTR 220 or 225 you are gonna leave a lot on the table, however id go with the 225 if it had to be one of those.
I had a TSP stage 2 (227/242 112LSA) and a .040 shave. The car had perfect street manners with a babies rockabye at a red light. To get the full potential out of the combo you'll need to upgrade your IM, I was pulling vacuum on my ported stocker and a ported 95. Unless something has developed and I'm not aware, you need to rev it to 7k and the car can only does that manually with the limits raised. I was at 6500 and was leaving a lot on the table.
Car went 10.4@133 iirc in 2k DA.
The SS3 cam has 19 degrees of overlap. For a rig that wants every last tenths in the qtr....maybe. It's going to fall on its face after every shift. It's going to run like **** on the street. A cam with 10 degrees less overlap is going to run WAY smoother and only give up a few HP above 6000 rpm. 19 degrees of overlap is just dumb on anything other than a dedicated drag Vette. For the money it takes to do heads/cam, and the drivability you're going to give up if you go with a stupidly big cam, a supercharger would be a better option.
That new trans controller that was just released will let it auto shift above 6500. Huge selling point of it on that alone. As far as Intakes go, the PTR will be the best bet.
Im going to disagree. The SS3 drives quite nice and has a nasty mid range. It’s never going to fall on its face. If I was going to go smaller Id go SS2 over the BTR offerings. GPI has shown solid results with that cam in the C8. Think it did like 565 wheel with only a minor head cut. Bump to 13:1 on E and it’s gonna run!
I love BTR as a company and Brian is a wealth of knowledge, but their sales staff isn’t as educated on their products as GPI. No one at BTR could tell me how much PTV clearance the 225 has, obviously you want to measure, but GPI has this info for all their cams. So it makes knowing what you are getting into much easier.
Here is what I'm getting, adding a E85 true flex fuel system that Peitz is the only shop in the Houston area that is DSX approved. Most of this is already pre-packaged with one choice is about the cam being the V220 or V225. I'm not going to deviate from this package.
Charlie
In-house fabricated Cat-back T-304 stainless exhaust system
Modular exhaust designed to be able to be used with turbos
Kooks long tube headers with stock cats
Halltech Hornet intake
Mighty Mouse catch can (Wild) w 10 AN lines
HP Tuners E99 ECM Upgrade
DSX flex fuel for E85
Dyno-proven calibration with tuning support
Options for professional installation, mail-out, and E85 tunes
Options for adding an MPVI 3 for diag/flashing
Up to 30 HP gains
Charlie Plus
Everything from the standard Charlie package
CNC ported heads optimizing flow and efficiency
Camshaft optimized for performance and drivability
Hardened pushrods
Trunion rocker upgrade
.660” lift valve springs
160 degree thermostat
Options for milling heads for higher compression w/E85
80+ HP gains with E85 and higher compression
Here is what I'm getting, adding a true flex fuel system that Peitz is the only shop in the Houston area that is DSX approved. Most of this is already pre-packaged with one choice is about the cam being the V220 or V225. I'm not going to deviate from this package.
When all in let us know how the car ends up and the chart before and after. Are at least after... good luck man
What rpm do you plan to shift at? To me the answer to that question answer’s which can to go with. Average power is what is fastest and if you’re not willing to shifter higher than stock then why go with a later IVC that moves the powerband up? Not so much worried about low end as you have instant electric torque to help with the launch.
Best quarter mile time before any mods 10.72 @ 127 in 900 DA. Had Mickeys street R, but I don't think drag radials help without a line lock or having AWD. In better DA, a 10.6 for sure and maybe a 10.5 could be had.
As far as cams go, I don't know enough about engines to even imply the two cams offered are a wrong choice. I'm going with the 225 vs the 220 which are the only options I have.
I do appreciate the suggestions that have been given, but I just don't know enough about engines to change or amend the package Peitz is offering.
Since you plan to run E85, see if Peitz will at least flycut your pistons so you can bump compression to 13:1. It's two hours extra labor max.
When is the car going in? I too am excited to see your results. I regret not buying a E-Ray, strongly considering the GSX.
I'm running this cam with 12.5:1 compression and it drives like stock under 3500rpm's except there is more torque down low.
238/247 .652/.630 110/118 icl/ecl (4* advance built in) 114 lsa
I'm thinking about the new trans controller as well. I currently shift at 7300rpm manually and frequently hit the rev limiter even with a shift light as it starts to pull faster at the revs climb.
My stock clutches start to slip at the top of 3rd if you are beating on it good and they get hot.
I think a little more pressure on the stock clutches (Stingray) and auto shift by RPM in manual may make for a decent setup.
But to your original question drivability and manners are mostly due to good tuning.
Are you running the BTR v220 or v225?
About your stock clutches slipping, are they slipping like mine did with my 2021 Z51 with E85 tuning and mickey street R's? You can see the slip in 4th gear at 4500 rpms which was stock clutches slipping. About 1:03 to 1:11 in the video.
