1963 E brake light
Old Yesterday | 08:26 PM
Mitch03Z06's Avatar
Mitch03Z06
Default 1963 E brake light
On my 63 I refurbished my cluster. I am not sure if the E brake light worked before I started the refurbish process. I replaced all of the bulbs, gages, and made sure the tech and speedo worked. After installing the cluster I noticed the E brake light stays on. I remove the wires from the switch and it went out. I then removed the switch and checked its function. When you push the plunger continuity is broken, so the switch works. What on the E brake rod trips the switch, is there a screw located on the rod that’s trips it. Any help is appreciated. Thanks, Mitch
Old Yesterday | 09:24 PM
65GGvert's Avatar
65GGvert
There's a stop pin that goes into the shaft that pushes open the switch when parking brake is off.
Old Today | 06:52 AM
Mitch03Z06's Avatar
Mitch03Z06
Default 1963 e brake
Thank you I’ll have to crawl under there later today and check to see if the pin is still there.
Old Today | 07:31 AM
Dave Strickland's Avatar
Dave Strickland
Don’t forget the #257 flashing light bulb.
Old Today | 08:13 AM
tbarb's Avatar
tbarb
I just want to add to be very careful with that emergency brake switch, it’s a one year only part. $$$. The GE 257 flashing bulbs are used in that circuit plus the headlight warning circuit.
Old Today | 08:18 AM
Mitch03Z06's Avatar
Mitch03Z06
I thought the flashing bulb wasn't used on the 63
To 1963 E brake light
