P0300 code after replacing parts
Old Jun 15, 2026 | 06:16 AM
MVR_CNY's Avatar
MVR_CNY
Cruising
Default P0300 code after replacing parts
Need some help with this one. I have a 2000 vert with a constant P0300 code after a few minutes at idle following some preventative maintenance. Mind you, the car ran perfectly well prior to replacing the oil pressure sensor, the camshaft position sensor, cleaned the TB and installed new intake manifold gaskets. After putting it all back together, the car runs rough and throws a P0300 code.
I double-checked all the electrical connections and vacuum lines and did not find any breaks or leaks. Thinking the new camshaft sensor maybe DOA, I reinstalled the original sensor but still get the P0300 code. Maybe there’s a hidden vacuum leak on the PCV system or a faulty MAP sensor on the rear of the intake manifold. I did not check the coil packs or spark plugs/wires since they were not replaced but should I?
Any suggestions on what’s causing the misfiring and error code?
Thanks!
Old Jun 15, 2026 | 07:32 AM
lucky131969's Avatar
lucky131969
What is your measured vacuum?
...but no cam DTCs
How many vacuum connections did you disturb?
....or a faulty MAP sensor on the rear of the intake manifold
What is your live data look like?
Did you follow the service manual procedure for torquing the manifold bolts? Did you use blue loctite?
Old Jun 15, 2026 | 07:43 AM
MVR_CNY's Avatar
MVR_CNY
Cruising
I don’t have a tool for that
...but no cam DTCs. Correct
other than the lines on the TB and the one on the manifold,
What is your live data look like? Didn’t want to run the car too long with multiple misfiring.
Yes to torque values but did not use loctite
Old Jun 15, 2026 | 08:03 AM
lucky131969
Then the clamping force is way off. The blue loctite specifically called out on the service manual acts as lubricant for the fastener, so you have a fraction of the clamping force applied for the design intent. Even more of a concern with brand new gaskets. I would start there.
Also, if you are asking for help and someone on the form time time to ask questions............take time to answer them.
Old Jun 15, 2026 | 08:09 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Save yourself time and money...take your car to a professional diagnostician if you can find one...you don't have the equipment or knowledge to fix this.
Old Jun 15, 2026 | 08:14 AM
MVR_CNY's Avatar
MVR_CNY
Cruising
Thanks the for the advice and appreciate your help. The manifold bolts did not have any evidence of loctite on them when I removed them, but that makes sense now.
As far as the gaskets; they are aftermarket (not GM) so I will change them to OEM gaskets.
Thanks again for the guidance.
Old Jun 15, 2026 | 08:21 AM
lucky131969
No. Do not add another variable! Use the gaskets you have installed.
Old Jun 15, 2026 | 08:30 AM
MVR_CNY's Avatar
MVR_CNY
Cruising
All I was asking for was some help from those who know more than I do on what to look for and not to be reminded that I don’t have the “equipment or knowledge” to diagnose a problem.
Honestly I did not think I would need to be a ASE certified mechanic or have $30,000 in tools to change out a few parts on a 26 year old car, but obviously I was wrong. I know these cars can be temperamental, but had no idea how much so kindly cut ne some slack, please.
Thanks!
Old Jun 15, 2026 | 09:50 AM
lucky131969
A
Honestly I did not think I would need to be a ASE certified mechanic or have $30,000 in tools to change out a few parts on a 26 year old car.......
To be fair.....you don't. What you do need is a factory service manual for your year car, and the aptitude/ability to understand the content and understand schematics. You don't need $30k in tools, but you do need the right tools. A baseline for troubleshooting tools.... like a spark tester, vacuum gauge, fuel pressure gauge, test light, DMM, and a scanner capable of reading live data. Keep in mind this is a C5 forum, addressing issues specific to a C5...........not a "how to work on cars forum".
Old Jun 15, 2026 | 12:16 PM
Jim53066's Avatar
Jim53066
I agree with the advice about finding someone that has the ability to perform diagnostics. Most good shops have thousands invested in their equipment to do just that.
What you are describing sounds exactly like a vehicle I had that needed a throttle body re-learn after some minor work was performed.
Unfortunately you are back to getting someone with diagnostic equipment to find out for sure.
JIM
Old Jun 16, 2026 | 03:33 PM
jjc508520's Avatar
jjc508520
My own P0300 story - with the Vortec engine in my RV (Chevy Express 3500 cutaway circa 2005). Started easy and seemed to run OK on the highway even though HP Tuners was reading misfires across all 8 cylinders. Took it to the shop and they said plugs and wires looked OK - in their words "The engine bay is in good shape and has not been messed with much" (only 55k on the clock). They then fitted a new crank sensor and while doing this found that one if the wires on the connector was burned! They installed a new sensor and wiring harness "and did a relearn procedure" and said the codes are gone. I'm on a trip with it now and will recheck when I get back.
Not sure if LS1 requires a "relearn procedure" but might be worth looking into
Old Today | 07:38 PM
MVR_CNY's Avatar
MVR_CNY
Cruising
Default Fixed!
First off, thank you for all the suggestions on what to check for.
  • Bought a service manual
  • Confirmed No vacuum leaks with smoke tester
  • Inspected plugs and wires.
  • Did resistance check on all wires, all passed
  • All plugs looked fine, gapped to spec
  • Flashed ECM with stock maps
  • Performed TB relearn
  • Noid tested all injectors - passed
  • Compression tested all cylinders - passed
  • Banged head against garage wall
  • Pulled valve covers and inspected springs and rockers
  • Banged head against wall again
  • Pulled data using HP Tuners and cylinders 1 & 4 had numerous misfires.
  • Replaced all plugs and wires
  • Problem gone! The car runs better than ever.
  • Put fresh gas in tank
  • Drank a beer
To P0300 code after replacing parts
