battery draining
Old Yesterday | 03:35 PM
ggrutt1957's Avatar
ggrutt1957
1st Gear
Default battery draining
My 81 Corvette is slowly draining the battery over about 2 days. I have changed the alternator 2x and ruled out that as a problem. I found a ground wire under the air filter housing that was chewed, I repaired the wire. Can't figure out where the power draw is coming from.
Old Yesterday | 05:41 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Pull a fuse at a time from the panel and monitor the battery drain -- I'd probably start with the clock/radio/gauges. Do you have any aftermarket alarm or such?
Old Yesterday | 05:51 PM
Newbomb2469's Avatar
Newbomb2469
Had a similar issue, turned out the center storage box has a light. If the lid is not fully closed, it stays on draining the battery. The fix is remove the light bulb.
Old Today | 12:37 AM
C3Cruiser's Avatar
C3Cruiser
A clamp style DC ammeter. You can clamp around 1 wire and measure amp flow through the wire when the key is off. You can check each wire as needed and find exactly which one is passing amps through it. Great tool to own.
To battery draining
