[C2] 327 glide, 220* @ 65 mph - 180* in traffic.
Unknown miles on engine, but Im “guessing” been rebuilt at some time in its life.
On a 70* day, AC off, cruising @ 65 - 70 on the freeway, RPM around 2500, temp gage gets to 220+ after about 10 minutes, but it cools back down to 180 - 190* after around 10 minutes and stay all day, if I’m in local traffic.
Checked with IR gun.
Timing is good (as per Lars papers)
BTW It did this before I recurved the dist. and swapped the thermostat out for a new 160*
New aluminium radiator (unknown brand) and coolant flows back to the surge tank when the thermostat opens, but how much, I don’t know.
So it would seem I have a coolant flow problem, not an air flow problem, even though there’s a trans cooler and condenser in front of the radiator.
It doesn’t puke coolant out, although I’ve only been up at that speed and temp for maybe 20 minutes and it takes half that time to come down again.
Hoses good, spring present and not collapsing.
Long post, sorry, just wanted to cover everything.
Should I even be concerned ?
Thanks for any advice, it’s a new one to me.
I’ve run it up to temp without the cap on the surge tank, so thought that would eliminate any trapped air.
There are a lot of gaps around the shroud that could be sealed better, perhaps that’ll help, but I’m also thinking, maybe the water pump impeller has rotted away.
I can see the flow of coolant back to the surge tank, so it’s working, but how well, is the question ?
