plugging off the brake master warning switch ?
Old Jun 18, 2026 | 05:22 PM
radar502's Avatar
radar502
Default plugging off the brake master warning switch ?
Replaced my 93 brake master the warning switch striped going into the new master can't seem to find a new one and not giving $100,00+ for a used one, was told I can just plug it,? Will that work .. Thanks
Old Jun 18, 2026 | 09:39 PM
81c3's Avatar
81c3
Should work and I think you need to jump across the terminals in the connector to keep the light off....
Old Jun 18, 2026 | 11:44 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
You should try to keep that light functional in my 2 bit opinion.
If you have to, maybe buy a crappy used master off of eBay or something and rob the switch from it.
If there's something wrong with your brakes you want to know about it before they fail. Well..assuming you value your life and the lives of others on the road should the brakes fail absent the brake light warning function.
Don't monkey around with the braking system and brake system warning devices. It's just not worth it.
Old Jun 19, 2026 | 05:44 AM
blackozvet's Avatar
blackozvet
Yes, you can block it. The tricky bit is you need one of these, a 12mm x 1.0 thread bolt, now you would think that it wouldn't be that hard to find one but it wasn't easy.
The switch is like a toggle between the front and rear lines, it will simply rock if one side puts out significantly more pressure than the other, activating the brake warning light.
Putting a block off bolt in does not activate the warning light.
Old Jun 19, 2026 | 07:38 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
It’s a dry port and a simple switch. Can you not add some silicone to the threads to keep it in position ?
Old Jun 19, 2026 | 08:27 AM
radar502's Avatar
radar502
Thanks for all the input, Thinking might try to glue it in or something, but I have a boilt ..THINKING
Old Jun 19, 2026 | 02:59 PM
Tunedperformancedotorg's Avatar
Supporting Vendor
I thi the xj late 80-90s Jeep had the same switch. Might look at a local junkyard
Old Jun 19, 2026 | 03:01 PM
radar502's Avatar
radar502
Thanks
Old Jun 19, 2026 | 04:36 PM
BET VETTE's Avatar
BET VETTE
https://www.corvetteforum.com/forums...m_content=post
To plugging off the brake master warning switch ?
