how to test my map sensor
Old Yesterday | 01:54 PM
usunited1@comcast.ne's Avatar
1st Gear
Default how to test my map sensor
my 1982 corvette crossfire throws a check engine light when i de-accelerate, goes off when i hit the throttle again, could it be the map sensor, i did remove the smog pump and lines but the plugins are still there, could that be the problem?
Old Yesterday | 04:36 PM
sunflower 1972's Avatar
sunflower 1972
Found this: https://www.corvetteforum.com/forums...-it-works.html
Old Yesterday | 08:37 PM
Fly skids up!'s Avatar
Fly skids up!
A hand vacuum pump and a scanner.
Being that you have a check engine light coming on constantly, you should be able to pull code.
To how to test my map sensor
