Southern California Southern California
Code Help!!!!!!!!!
Old Nov 6, 2005 | 01:53 PM
CN RED's Avatar
CN RED
Default Code Help!!!!!!!!!
A friend went to go get his car SMOG Checked and he's throwing this code. Could someone please help with this code and what it means.
Here's the CODE P0343
Thanks in advance.
CN RED
Old Nov 6, 2005 | 02:38 PM
EPiC Vette's Avatar
EPiC Vette
Model? Year? Tranny? Mods?
Old Nov 6, 2005 | 04:05 PM
CN RED's Avatar
CN RED
99 is the year, Auto tranny, no mods
CN RED
Old Nov 6, 2005 | 05:42 PM
jmzvet's Avatar
jmzvet
P0343 CMP Sensor Circuit High Voltage No idea what it means though.
Code list:
http://www.stengel.net/diccodes.htm
Old Nov 6, 2005 | 06:44 PM
SNAKEKILLER!'s Avatar
SNAKEKILLER!
Default High voltage....
Thanks in advance.
CN RED
Check the current in you're altenator.....also check the voltage on you're battery...
Old Nov 7, 2005 | 10:50 PM
mdkenz06's Avatar
mdkenz06
Cruising
Default Setting P0343
I'm setting the same code in an '02 Z06 w/ ATI procharger (original kit), headers, random tech x-pipe & cats, borla stingers. I have occasionally had the message Charging system failure occur when starting. I've noticed that my voltage while running is about 13.8-14.2. I've seen it drop lower as well while running along at 2500 rpm. Using EFILive I can see that the low to high and high to low transition counters increment and match so I was looking for another explanation. After reading some threads it looks like the new alternators are 140amp vs. 110. Does it sound like I should give that a try based off of the symptoms?
Thanks,
Ken
To Code Help!!!!!!!!!
