Southern California Southern California
four corner balancing improves performance.
Old Feb 18, 2008 | 07:37 PM
bruce1's Avatar
bruce1
Default four corner balancing improves performance.
http://forums.corvetteforum.com/show....php?t=1118158
Old Feb 18, 2008 | 08:25 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Looks like an AWESOME time!!!
Old Feb 18, 2008 | 08:34 PM
Brandon619's Avatar
Brandon619
Right on, Kushan is a great tuner .
Old Feb 18, 2008 | 10:37 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Another here for Kushan, he does top QUALITY work!
He just installed a new blower-cam/Edelbrock 215 heads and re-tuned my Maggie, average +40/50hp/tq on the low and mid-range, around +80hp/tq @ 5k-5600rpm and ended up with a peak hp gain of 118rwhp....... nice!
I`ve got new r-compound tires in route for install, corner balancing/alignment!
Old Feb 18, 2008 | 10:40 PM
bruce1's Avatar
bruce1
Old Feb 18, 2008 | 10:45 PM
Brandon619's Avatar
Brandon619
Congrads on your new setup Rick I know you put some coin into your baby .
Old Feb 19, 2008 | 10:39 AM
RoHo's Avatar
RoHo
Bruce, are you guys running coil overs? I was told that you can't corner balance a cross spring suspension like the Z's have.
Have I been misinformed?
Old Feb 19, 2008 | 01:04 PM
Rag-Top Rick
Rog, they are running coil-overs and I can`t answer specifically for the stock C6/Z but Kushan told me he could corner balance my C5 as each corner is adjustable.
Old Feb 19, 2008 | 01:13 PM
bruce1's Avatar
bruce1
I am indeed running coil overs, but even it I wasn't, and even if I had the stock (leaf spring) suspension, 4 corner balancing enhances the performance. Kushan balanced his stock set up and turned in his quickest lap time last month.
Call Kushan for more technical information.
Bruce
Old Feb 19, 2008 | 01:27 PM
RoHo's Avatar
RoHo
I have been holding off to get a road and track alignment (per specs on the CF) on my Z because I wanted to get it corner balanced, but was told they couldn't do it for a cross spring, I will go talk to Kushan about this.
Is he doing his own aligments now or still using True Line?
Old Feb 19, 2008 | 01:37 PM
bruce1's Avatar
bruce1
again, give Kushan a call.... he can get you the info.
Old Feb 19, 2008 | 06:08 PM
SILVR STREAK's Avatar
SILVR STREAK
Kushan scores again. My car handles fantastic since I did the Coil Overs and had the 4 corner balance.
Old Feb 19, 2008 | 07:51 PM
Brandon619's Avatar
Brandon619
He uses True Line for aligments and you can ruff balance a stock C5 suspension. I did mine by eye and checked it on Kushans four corner system and I was close .
Old Feb 19, 2008 | 08:09 PM
Olitho's Avatar
Olitho
I have never heard of a cross-spring, but of course you can set ride-height and corner balance a Corvette with stock springs or coil-overs.
Cross-spring sounds like another name for the mono-leaf.
To four corner balancing improves performance.
