Active handling question
Thanks in advance.
RJ
Thanks in advance.
RJ
Most of the times I've seen it, it's been associated with having the front wheels turned when you start up and drive off. Say you pull into a parking space and the wheels are turned to the left - you go to back out and crank the wheel in the opposite direction before you actually start to move, and it throws a code...
Both my '05 and '07 have done the things described above. It had nothing to do with wheel position while parked. It happens MANY miles removed from being parked. Besides, in my garage, the wheels must be staight to even get the car in.
Been reading up on this stuff in case I get one of these "Computers" with 4 wheels...
From the manual (happens to be the '06 manual):
"When you first start your vehicle during cold winter
weather and begin to drive away, the message ACTIVE
HANDLING WARMING UP may be displayed in the
DIC. This is normal. You can acknowledge this message
by pressing the RESET button. The Active Handling
System performance is affected until the message,
ACTIVE HANDLING READY, is displayed in the DIC.
The ACTIVE HANDLING CALIBRATING message may
be displayed in the DIC and the instrument panel
cluster light will be on after exceeding 18 mph (30 km/h)
for 10 seconds. The Active Handling System is off
until the ACTIVE HANDLING READY message
is displayed. This could take up to 15 minutes."
No, I never get the "Service Active Handling", so no worries there.
Like Earl said, this happens many miles after leaving my garage.
One thing to note: this has never happened before the blower was installed. Don't know if that is relevant or not, but glad to hear it is probably just a "techie - thing" like Jason said.
Looking forward to seeing info on where/when the Varmits' group will meet for the ride up to the CF Pinic.
KUDOS ON A GREAT JOB, Jason.
