Southern California Southern California
Engine detailer
Old Aug 17, 2008 | 03:33 PM
jserio's Avatar
jserio
O.C.
Default Engine detailer
Guys, I am in desparate need on a great engine detailer in LA/OC county area. My engine area is a disaster and I want someone that will not screw up the electronics or anything else for that matter. Any ideas?
Old Aug 17, 2008 | 10:04 PM
stano's Avatar
stano
Adam's makes an engine spray detailer called "In & out Spray" that works awesome. I've used it. Give it a shot. Takes minutes and a little wiping, but not much. 1/2 hour or less should do it with minimal wiping.
Old Aug 17, 2008 | 11:45 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Old Aug 18, 2008 | 01:30 PM
jserio's Avatar
jserio
O.C.
I know Adam's but can't remember for the life of me who local is dealing their stuff.
Old Aug 18, 2008 | 06:04 PM
rayluka's Avatar
rayluka
Jason can help you. LS1fun on this forum
Old Aug 19, 2008 | 12:20 PM
fast howard's Avatar
fast howard
Default engine detailer
i have been detailing corvettes for the last 35 years (my own personal cars and friends). i last completed a 2002 convert. for one of the corvette club members (pacific coast corvettes). i use various chemicals and power washers, along with other preservatives for car show quality results. i have discovered a new cleaner for the new plastic covered corvette engine parts. go to your local harley davidson dealership and pick up " bike brite" and follow the instructions. cover the electronics with paper towls and encapsulate the areas with aluminium foil, and use a leaf blower (heavy duty) after hosing off the engine. unless the c-5,6 is realy cruddy, that should do it.
fast howard
Old Aug 19, 2008 | 03:18 PM
rayluka's Avatar
rayluka
If your looking for someone to do it I am local. Swing by on a weekend evening and I'll give you a hand or can do it for a price. I posted mine so you can see the difference I did to mine.
And of course after
Old Aug 19, 2008 | 08:34 PM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
Nice job Ray. But that is more than just spit & polish. It looks like you painted a lot of stuff.
Old Aug 19, 2008 | 11:37 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Wow Now that's the type of job that makes us all proud! It's refreshing to see when someone does the job right! Great job
Old Aug 20, 2008 | 10:43 AM
rayluka's Avatar
rayluka
True Mike but it sure took a lot of spit,polish and elbow grease even before the paint...whew
Old Aug 20, 2008 | 12:00 PM
fast howard
Great job on the c-3 engine compartment.
Fast howard
p.s. Big differance between a c-3 and a c-5 engine compartment.
Old Aug 20, 2008 | 01:25 PM
rayluka's Avatar
rayluka
Very true. C-3 is pretty easy to do.
Old Aug 20, 2008 | 03:18 PM
jimman's Avatar
jimman
Simple Green and a water hose. Spray on the Green water spray it off and go drive fast for 5 min then go have lunch.
Old Aug 22, 2008 | 02:28 AM
Z06Fanatic's Avatar
Z06Fanatic
Default Got my Engine detailed by Jesse @ www.shinetech.com
BEFORE:
BEFORE:
AND AFTER:
AFTER:
Oh my goodness! This guy made it seem like my valve covers were turned on! They are super bright now! In fact he detailed the entire car...took him 14 hours. This guy knows what he's doing and has the patience for perfection. He worked on it as if it were his own car. He's in LA/OC Area. You should contact him to ask how much for the engine only. Worth every penny! www.shinetechautodetail.com
Here's the link to the write up he did on the entire car:
http://www.meguiarsonline.com/forums...ad.php?t=26444
Old Aug 22, 2008 | 11:53 AM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
That is not advised for the lsx engines!!Water can get down in and corrode/ruin the knock sensors,then you have a lil' problem
Good idea for other engine bays though if you protect whatever electronics
Old Aug 22, 2008 | 03:22 PM
HeadPapago's Avatar
HeadPapago
btw, the link to Shine Tech is not the right company...
Old Aug 23, 2008 | 09:54 AM
Z06Fanatic's Avatar
Z06Fanatic
Fixed: www.shinetechautodetail.com
Old Aug 23, 2008 | 01:42 PM
1bdasvt's Avatar
1bdasvt
Might just give Him a call!
Looks very nice!!
Old Aug 23, 2008 | 10:54 PM
jserio's Avatar
jserio
O.C.
Thanks Guys, Looks like Jesse is the guy I'm looking for.
To Engine detailer
