Project Problem Child update and ring gap question...
Jeez, I'm not used to that kind of quick turnaround time. I was expecting things to be done in late March.
Anyway this thing ate its bearings to they're all going to be replaced. The proprieter of the new shop took a good close look at all my rings. He says they're OK. They're SpeedPro plasma moly so they'd be kind of expensive to replace.
However, I'm going to check all the gaps before I reassemble anything. I figure if someone could overlook properly sealing the splayed studs on the main caps, it's possible the ring gaps were glossed over, too.
EDIT: I got the ring gap info I need from SpeedPro...
[Modified by The Dude, 9:40 PM 2/8/2002]
