Southern California Southern California
Fuel Level Sensor Replacement Cost
Old Jan 21, 2010 | 11:29 AM
Jimbeaux's Avatar
Jimbeaux
Default Fuel Level Sensor Replacement Cost
Hello All,
Looks like I have a faulty fuel level sensor that needs replacing.
Since it is labor intensive and costly, I will have both the right side and left side sensors replaced. Team Chevrolet in in Pasadena quoted $2,700 to do the job. This seems a little steep to me.
Has anyone had this done and if so how much did it cost? (car is out of waranty).
Old Jan 21, 2010 | 01:03 PM
saxtech's Avatar
saxtech
From: Huntington Beach / Fountain Valley California
Originally Posted by Jimbeaux
Hello All,
WOW - I'm sure you've tried the quick fixes here first (Techron) ???
Just curious - What brand gas do you regularly use ?
Old Jan 21, 2010 | 01:18 PM
GRUNIE's Avatar
GRUNIE
Try running a few bottles of Techron. It sure worked wonders for my fuel sensors.
Old Jan 21, 2010 | 01:41 PM
Jimbeaux's Avatar
Jimbeaux
Yep, gone through two bottles of Techron. I also use Chevron gas exclusivley. I replaced the gas cap as well. Gas gauge still drops to zero and the check engine light came on again this morning.
Old Jan 21, 2010 | 02:03 PM
Keith N's Avatar
Keith N
Jim - I would call several dealerships before I spend $2700 for the repair. Try giving Lake Chevrolet in Lake Elsinore a call or some local Corvette Performance Shops - RPM Motors (Santa Clarita), CMS (Lake Elsinore), A&A Corvette (Oxnard) for estimates. Good luck!
Old Jan 22, 2010 | 11:39 AM
Jimbeaux's Avatar
Jimbeaux
Thanks for the suggestions. I will do some further checking.
Old Jan 22, 2010 | 07:40 PM
saxtech's Avatar
saxtech
Please let us know what you find out and make sure they actually "troubleshoot" your problem before just changing parts un-necessarily. If they say its the sending unit in the tank then ask them how they know this - They should be able to tell you how they troubleshooted the prob. (readings on volt/ohm meter and where they got the readings, ect. ect. ect)
This is one of my worst fears - second is the Oil Pressure Sender - Have you had problems with that yet.
I guess I'm worried because I have only had my Vette with 24k miles for only 2 months now (it's a 99).
So keep us up to date.
Old Jan 22, 2010 | 08:34 PM
Jimbeaux's Avatar
Jimbeaux
Thanks Sax. I have not experienced any oil pressure sending unit problems yet. I will keep you posted on this problem though.
Old Jan 22, 2010 | 08:35 PM
Jimbeaux's Avatar
Jimbeaux
I also wanted to add that since this problem started I'm also getting the service fuel system message on the DIC. The dealer in Pasadena pulled the code which pointed to the sensor on the right side.
Old Jan 27, 2010 | 12:14 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
Had mine changed along with new pulleys & belt came to just over $3k paid by warranty co. The feelers on the sensor disentigrated
To Fuel Level Sensor Replacement Cost
