Southern California Southern California
Preferred Brake Bleeding Method
Old Mar 6, 2010 | 08:21 PM
boblav's Avatar
boblav
St. Jude Donor '10
Default Preferred Brake Bleeding Method
What method do you guys prefer?
-pressure bleed, like the Motiv, very easy, one man, but the cleanup with denatured alchohol when done is a pain
-check valve bleeder screws, sounds pretty easy, do they work?
-hand held vacuum pump, like the Mityvac (metal, not plastic), works OK, again the cleanup
-old school, two people
Old Mar 6, 2010 | 08:26 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
It makes my 16 yo son get off his but!
Old Mar 6, 2010 | 08:56 PM
Dirty Howie's Avatar
Dirty Howie
Myself with speed bleeders ..... never a problem in 5 years
DH
Old Mar 6, 2010 | 08:59 PM
Keith N's Avatar
Keith N
Bob - If you need some help, I've got a strong right leg! Just LMK I should be able to reach to brake pedal.
Old Mar 6, 2010 | 09:17 PM
boblav's Avatar
boblav
St. Jude Donor '10
DH
DH,
With the speed bleeders, do you attach a 3/16"id hose that will drain to a small container, then loosen up the bleeder and pump the pedal? I guess the master should be full, before you start at each wheel. Is it that simple?
Old Mar 6, 2010 | 09:20 PM
boblav's Avatar
boblav
St. Jude Donor '10
Keith,
I'm looking for a quick, clean & fast method with the least amount of clean up. It sounds like the speed bleeders might be the way to go. Thanks for the offer, I might take you up on it!
Old Mar 6, 2010 | 10:30 PM
blown34's Avatar
blown34
It's a ten minute job with the Motiv pressure bleeder; I attach a one pint bottle to the hose and bleeder valve for just a quick bleed or just a hose to the bleeder and let it hang in a oil drain bucket for a complete flush.
Old Mar 6, 2010 | 11:27 PM
Dirty Howie
DH,
Yes, its that simple.
I actually gave one of those cheap plastic bags with the hose attatched, so there are no bottles to knock over or hose to flip out of the bottle ....no mess !!!!!!!
DH
Old Mar 7, 2010 | 08:00 PM
pauldana's Avatar
pauldana
Bob, I have a power bleeder you can borrow... its simply the best way
Old Mar 7, 2010 | 10:14 PM
boblav's Avatar
boblav
St. Jude Donor '10
Thanks Paul, the Motiv is about $65 with the adapter, so I would just buy it. But I think I'm going the speed bleeder route, its very quick, clean and easy.
Old Mar 9, 2010 | 10:37 PM
Lrod's Avatar
Lrod
speed bleeders, they're always on the car and can't get misplaced or loaned out to your brother-in - law who never returns anything loaned.
To Preferred Brake Bleeding Method
