Southern California Southern California
C5 conv trunk struts
Old Nov 26, 2011 | 12:07 AM
misnracn's Avatar
misnracn
Default C5 conv trunk struts
I ordered new trunk struts. When they came, they are 1" shorter than the ones on the car They tell me they are correct. the ones on the car are 12" overall length, the new ones are 11". Can someone with a C5 conv measure their struts for me, so I'll know which is correct.
Old Nov 26, 2011 | 10:30 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
Also measure the extended length. It's possible the 12" struts may not extend any further than the 11's.
Just a thought.
Old Nov 26, 2011 | 10:38 AM
misnracn's Avatar
misnracn
These are the extended lengths. The ones on the car were measured with the trunk all the way open, the new ones come extended.
Old Nov 26, 2011 | 01:15 PM
LS2NSUV's Avatar
LS2NSUV
Don't have a vert, but the Z should be the same. Measured at 12" fully extended.
I'm assuming the 11s will prolly work, but the lid will obviously not open as much. And if you do decide to install them, close carefully and slowly making sure they don't put the hinges in a bind.
On a personal note, I think I would tell the place you purchased them from that there full of kaka. That is unless someone with a vert chimes in and states that theirs are only 11". This might mean at some point a previous owner could have changed them prior to your ownership.
You also might want to post your thread on C5 general discussion. Might get a wider and quicker response.
Old Nov 26, 2011 | 01:32 PM
misnracn's Avatar
misnracn
Thanks, I believe the Z is the same. I think I will return them. There is a big difference in how far they open, Zip says they are correct, but I don't think so.
Old Nov 26, 2011 | 03:04 PM
02spdwywhtvert's Avatar
02spdwywhtvert
Ok misnracn, I meassured the trunk struts on my 02 vert and these are the correct meassurements:
compressed = 8 inches
fully extended = 12 inches
I hope this helps!
Old Nov 26, 2011 | 03:12 PM
misnracn's Avatar
misnracn
Thank You, ZIP has a problem with wrong packaging or supplier, I'm going to return them.
To C5 conv trunk struts
