C5 Mechanic
Go see Carl at corvette mike in anaheim
http://www.competitiongt.com/
First make sure your differential is not over full and leaking out the top vent before you replace an axle seal.
C5 Differential
The differential hasn't been touched since I took delivery. It now has 105,000 miles The appears to be a hose on the top coming from the diff. and has a unclean cut that I can see and don't know where it goes, it is just hanging there. Is this a vent or should it be attached to something.
Is the diff. separate from the Auto trans and don't share fluids?
Thanks for all the help, but still looking for a local honest mechanic in south Orange County of Calif.
Ciao
Ciao
